Cascadia antilock braking activates way too much
Discussion in 'Freightliner Forum' started by slow.rider, May 31, 2021.
  1. slow.rider
    slow.rider Road Train Member
    2,005
    4,740
    Apr 4, 2017
    NYC
    13 Cascadia, getting antilock during any braking stronger than gentle brake-assisted deceleration. Sounds and feels like it might only be coming from the passenger steer. Any ideas?
    Rideandrepair Thanks this.
  3. Lucky12
    Lucky12 Medium Load Member
    600
    2,297
    Nov 24, 2019
    Could be ABS sensor failing, it's telling ABS system wheel has stopped turning, activating the ABS to get it rolling again. Probably the one on the passenger side, obv.
    Rideandrepair and slow.rider Thank this.
  4. slow.rider
    2,005
    4,740
    Apr 4, 2017
    NYC
    Thanks. Is that a big deal to replace?
  5. jason6541
    jason6541 Road Train Member
    2,425
    5,356
    Mar 5, 2012
    Omaha, NE
    Honestly with brakes take it in and have abs system tested. They can run a test while truck in motion to see which
    Abs wheel speed sensor is not reading correctly, modulator valve may be hanging. Yes maybe a bit spendy for diagnosis. But guarantee cheaper than guessing and throwing parts at it. Could be effecting the traction control system as well.
  6. slow.rider
    2,005
    4,740
    Apr 4, 2017
    NYC
    Thank you. I'd be interested in finding a place that could do that while I wait, as opposed to dropping it off at the crappy dealerships out here and waiting two weeks for them to touch it. What are my odds of finding such a place?
  7. rbrtwbstr
    rbrtwbstr Road Train Member
    3,210
    7,112
    Jul 11, 2012
    in the bush somewhere
    Could you call ahead and make an appointment somewhere along your route?
  8. slow.rider
    2,005
    4,740
    Apr 4, 2017
    NYC
    I could.
  9. jason6541
    2,425
    5,356
    Mar 5, 2012
    Omaha, NE
    May want to check with T/A Petro not a great place but they should be able to run diag on ABS system
  10. Old Man
    Old Man Road Train Member
    4,597
    13,466
    Apr 3, 2009
    Oklahoma City, OK
    Most have a laptop to plug in to the port.
    slow.rider and Rideandrepair Thank this.
  11. Rideandrepair
    16,526
    53,943
    Aug 8, 2015
    I don’t know about the new Trucks, but my old 2000 Shaker has a diagnosis switch on the ABS module, located under the bunk, behind passenger seat. Take cover off, turn ignition on, hold button a couple seconds and get the blink code from dash light. I’ve got a code list. What you should do first, before anything is open the hood, look for the wire leading to the sensor in back of the hub. Fronts are usually easily accessible. Push it in, make sure it’s bottomed our against the hubs tone ring, note if it moves. Might just have slipped out some, and is gapped too much. Easy fix. Loose bearings will make it happen again. Could also just be a rusted out sleeve that goes around the sensor to hold it in, easily changed especially on the front, without taking the wheel off. My right front was out too far a while back. Simply pushed it in. Problem solved. A month later seal blew out. I think it may have been seeping, and caused the sensor to slip out, before it blew. Not sure. Just something to look for.
    slow.rider Thanks this.
