Cascadia noisy at starting gear.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by medseg2003, Oct 9, 2024.
  1. medseg2003
    medseg2003 Bobtail Member
    26
    7
    Aug 11, 2017
    Hi everyone,
    I have 2013 cascadia 10 speed eaton transmission. Today I have noise under the truck when start rolling .after each full stop when i put in the gear i hear nothing but when i start taking my foot off the clutch and start rolling a loud grinding noise under truck .
    it happens only at starting gear.when i shift to the next gears is normal no noise. Is this can be a sign of transmission getting bad? Or can be clutch or drive shaft.
    Also i would like to mention when driving on highway i have to accelerate slowly to reach high speed if accelerate normally like i used to the RPM will rev up and return back it's like telling me giving gas more than truck can get.
    Samething happens when i use cruise . If i am cruising at 70 mph cruise just quit on it's own when it feels like that's too much for the truck.
    before i used to cruise 70 pmh with no problem.
    Anyone face this problem before?
    Please help . Thanks alot!
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Time to get it looked. I would go get that checked out immediately. You don't want to wait. You are asking for something major to happen by continuing to run it.
  4. Brandt
    Brandt Road Train Member
    4,674
    6,478
    Sep 17, 2012
    Sounds like the clutch is slipping when you apply power. Maybe it related to the grinding noise probably need a new clutch
    Crude Truckin' Thanks this.
  5. Luwi67
    Luwi67 Heavy Load Member
    754
    494
    Oct 24, 2012
    Long island
    What is your free play at the clutch pedal?
  6. AModelCat
    166,503
    Classic symptoms of a slipping clutch. You might get lucky and an adjustment might fix it but I wouldn't hold my breath.
