Cascadia wet drain not opening
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by semitosemi, Jul 14, 2025.
  1. semitosemi
    semitosemi Bobtail Member
    14
    12
    Nov 4, 2009
    Central Texas
    2022 Cascadia, I'm a company driver. The wet drain gets to where it does not open when I pull on the cable. I have to reach under and push on the top of the valve. Is this due to powdered rust clogging the valve, or what, and what can I do to make it work better? Thanks
  3. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,961
    Oct 31, 2023
    They get gunked up on the inside. Corrosion can happen too but they're brass so it's not a huge deal. Just write it up and have your employer replace it.
    semitosemi Thanks this.
  4. Ridgeline
    22,777
    124,549
    The air dryer needs to be fixed.
  5. Big Road Skateboard
    7,280
    41,489
    May 2, 2021
    You could replace it to make it work better
  6. semitosemi
    14
    12
    Nov 4, 2009
    Central Texas
  7. Numb
    Numb Crusty Curmudgeon
    4,373
    10,420
    Jan 30, 2012
    Charlotte, N.Carolina
    he's a company driver.
  8. Big Road Skateboard
    7,280
    41,489
    May 2, 2021
    And he asked a question. I answered it.
    Maybe we should regulate who asks questions. Then get real serious, and regulate the ones who answer em
    semitosemi and kwswan Thank this.
  9. Numb
    4,373
    10,420
    Jan 30, 2012
  10. semitosemi
    14
    12
    Nov 4, 2009
    Central Texas
    Hey, thanks to everyone for their help. I'm driving for a mega, and service quality varies from terminal to terminal. I'll probably live with it until I get to a terminal shop and see if they want the job. This is a higher mileage truck so we'll see....
    Numb Thanks this.
  11. Big Road Skateboard
    7,280
    41,489
    May 2, 2021
    You could try spraying a penetrating oil or lubricant on it and force it open, then spray some more. It might get a little around the valve and loosen up
