I drive a 1994 KW T800, it has a 3406 in it but I’m not sure which series it is. Casting on the head reads 018402 and 3K04. There was no tag on the valve covers as I have read about elsewhere. Are these the numbers needed to ID it? If so what is it? I think it’s a C but it could be a B too I suppose.![]()
Cat 3406 ID help
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cdubb, Mar 7, 2021.
The needed number is stamped on the rh side of the engine block, pass side.
I've seen them stamped mid-block on the driver's side as well.
Look at the pump. Is it a 7E-5888 pump or 7W-3906?
Also, does it have the big square port exhaust manifold or is it a round port that reassembles a 3406E or C15?Cdubb Thanks this. -
If you call the dealer with the VIN number can't they tell you the exact model of the engine?
In the door jam it might have a tag somewhere that says “3406peec” or 3406atac” if it’s the later, it’s a 3ZJ engine the peec engine has an 8PN serial number..........unless the engine has been swapped.
The 3ZJ could have been a B or C though. When Cat transferred alot of part numbers over to the new system in the early 90s, they had alot mixed up info on serial numbers. Thats why I asked which manifold or pump it had. Not only that, but that engine could be a transplant.Last edited: Mar 9, 2021
