I’ve got a 3406b cat in a toter home that won’t start when it’s up to operating temp. Starts good cold. Runs down the road ok. We’ve replaced the lift pump, primer,all rubber fuel lines, the plungers and barrels in the pump. When it’s warmed up it will crank till the battery’s run dead. Give it a shot of starting fluid and it pops right off and idles good and runs down the road good. Anyone have any ideas? Motor has approximately 50,000mi on an in frame and new nozzles
Cat 3406b won’t start when hot
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Underdog buggy, Feb 24, 2021.
Maybe check the voltage to the fuel solenoid while it is cranking. Maybe even take it off. Thank that is the one that pulls the plunger in to run. Cut the rod off of one the side of the road once and put it back on. It ran just would not shut down. Thank the A's worked opposite.
Just some thoughts as I never had that exact problem. -
I pulled the shutoff solenoid and still no start. Crazy because it starts so good when it’s cold but needs either when it’s up to temp.
Very strange. Can we see a picture of your truck and the side of the engine with the pump and lines?
Have you removed the filters after it gets hot to see if they are full? I'm not going anywhere with this, but it may lead to your problem.
Looks good and like you have done a lot of work on that. I am at a bit of a loss never having see that.
A couple of things I would want to check is the fuel pressure on the left filter head. Would need to have a gauge plumbed into it, it is an o-ring fitting #4?
Really sounds like a injection pump problem to me but I know you have had work done on it. Kind of jack leg deal and not so simple on your engine but I will share this. It was a Lull or similar machine built on a 5000 Ford tractor. It would start misfiring on two cylinders when hot. This was a 40 mile out in the country service call. I pulled an injector and managed to connect to the injector line without bending it. Tightened it back to the pump and injector and ran the engine. It did not spray fuel. Connected to the pump on a working cylinder and if sprayed fuel. All doubts removed in the county with little to work with. An injector spraying fuel like that can push it into the skin or put an eye out. Take no changes. The engine running with an open injector hole is also quite loud.
Maybe someone else has some better ideals?
