Cat c15 loss of power
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by anthonyar4, Jan 11, 2021.
  1. anthonyar4
    anthonyar4 Medium Load Member
    431
    92
    Jun 8, 2019
    Found my intake clamp right at the elbow was loose would this cause a loss of power?
  3. lester
    2,819
    7,479
    Jan 2, 2012
    NW, Iowa
    If it was loose I would have expected it to blow off under boost pressure. When you put 30 psi of air pressure things tend to blow apart. Butnthat said if it was loose and leaking yeah that could cause some power loss
  4. anthonyar4
    431
    92
    Jun 8, 2019
    So we are talking about the intake part the center of the turbo? Right. Not the CAC air.
  5. lester
    2,819
    7,479
    Jan 2, 2012
    NW, Iowa
    Oh i thought you meant the intake on the head. If you are talking about the intake on the turbo then, no I would NOT expect a power loss from that
  6. anthonyar4
    431
    92
    Jun 8, 2019
    I had a power loss under load all tests good. It drives fine till you get it loaded or around 1500 rpm then misses.
  7. anthonyar4
    431
    92
    Jun 8, 2019
    But the power loss was almost all engine power
  8. lester
    2,819
    7,479
    Jan 2, 2012
    NW, Iowa
    what is the rest of the story here? Assuming you found the loose clamp and you have been running the truck why are you asking this question. Did you notice a difference after tightening the clamp back up??
  9. anthonyar4
    431
    92
    Jun 8, 2019
    Seems to drive fine but I’m bob tailing now just don’t want to hook back on trailer and be screwed again.
  10. anthonyar4
    431
    92
    Jun 8, 2019
    Loss of power shake and stutter. Idles fine so I called wrecker get it to cat all tests good inj cutout, solenoid. And fuel restriction. I keep hammering it and it seems fine just don’t want to put 80k on and be dead again.
  11. lester
    2,819
    7,479
    Jan 2, 2012
    NW, Iowa
    Yeah I dont see how a loose clamp on the intake side of the turbo could cause any sort of major power loss. Unless the boot was terrible loose and didn't seal at all you could have been sucking dust and dirt, water whatever into the engine and destroyed it, but if that was the case I think you'd have a ton of blow by.
    What test have you ran? A miss under load at higher rpm would be a fuel problem if i had to guess. Do you have a fuel pressure gauge?
