CAT C15 MXS IVA warm-up control solenoid question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by west_coaster, Mar 28, 2017.
  1. west_coaster
    west_coaster Bobtail Member
    28
    20
    Jan 12, 2014
    Hey guys, question about the Valve Group Warm-Up Solenoid controler for the IVA on my 2005 C15 MXS. I had a code 95 and replaced the oil sensor on the top of the motor next to the front valve cover. Now I'm noticing that the warm-up control solenoid just in front of the sensor (sticking laterally out of the engine) is clicking (cycling) when I turn the key to the 'on' position. It cycles for about 20 seconds or so regularly about every second. Is this normal? I've never noticed it before and I'm wondering if this is causing some rough-running issues especially when colder than about 150-160 degrees. Any help is greatly appreciated. The CAT part # is 228-4800.
  3. SAR
    SAR Road Train Member
    2,756
    36,652
    Nov 26, 2011
    ND
    The rough running condition your talking about is that when you first start down the road and is sputtering or coughing, and puffing out smoke? My MXS will do that too from time to time if I don't let if warm up properly. Code 95 is intake valve actuation oil pressure sensor. Sounds about right on the one you replaced. Should be on the front passenger side of motor by t-state housing. When I turn my key on I also hear clicking noises in the engine area. Sometimes it lasts a short time others it will go on longer.
    I will tag @GrapeApe for you he is very knowledgeable on the acerts. Good luck
    Oxbow Thanks this.
  4. west_coaster
    28
    20
    Jan 12, 2014
    Yes, I. Can't really put a load in it until it's good and warmed up without it sputtering like the Jake is kicking on a bit. Just had the overhead set not too long ago and had a new IVA installed at that time.
  5. SAR
    2,756
    36,652
    Nov 26, 2011
    ND
    Before all these parts you replaced, did it run fine before?
    Oxbow Thanks this.
  6. west_coaster
    28
    20
    Jan 12, 2014
    No, it ran like crap. I replaced two Injectors, an exhaust spring, and the IVA head and all studs upgraded. Ran great for a few months up until recently when it threw the 95 code and I replaced the oil sensor for the IVA system. Now it had a definitive stumble when cold and a slight feeling of a slight miss under a load. Oil and fuel pressure are good.
  7. SAR
    2,756
    36,652
    Nov 26, 2011
    ND
    I am getting stumped now. I wonder if there is something wrong with 1 of the other 4 injectors? Is it throwing any codes at you when it is running rough?
  8. west_coaster
    28
    20
    Jan 12, 2014
    The check engine flashes but then goes back out. I need to stop into the shop and have them double check that the injector trim codes were entered properly. I'm not too familiar with the the ecm, but I was going to have them check to see of there are stored codes or something.
  9. SAR
    2,756
    36,652
    Nov 26, 2011
    ND
    If there is any stored codes you can retrieve them from using your cruise control toggle switches. To check that you turn your key on, turn your cruise control switch off and then hold your set/resume switch down for a few seconds, then release. Watch your check engine light flash. If it flashes 5 times, then a slight pause, 5 more times (code 55) then that means no codes active.
    Oxbow Thanks this.
  10. SAR
    2,756
    36,652
    Nov 26, 2011
    ND
    Here is a code list for an acert
    Flash DTC SPN-FMI DIAGNOSTIC CODE DESCRIPTION
    00 84-14 84-14 QUICKSTOP OCCURRENCE
    00 52-11 52-11 INLET AIR SHUTOFF SHUTDOWN
    00 166-14 166-14 RATED ENGINE POWER SPECIAL INSTRUCTIONS
    00 246-11 597-11 BRAKE PEDAL SWITCH #1 FAULT
    00 247-11 603-11 BRAKE PEDAL SWITCH #2 FAULT
    00 171-03 171-03 OUTSIDE AIR TEMP SENSOR VOLTAGE HIGH
    00 171-04 171-04 OUTSIDE AIR TEMP SENSOR VOLTAGE LOW
    00 171-11 171-11 OUTSIDE AIR TEMP DATA LOST
    01 71-00 71-00 IDLE SHUTDOWN OVERRIDE
    12 111-02 111-02 INVALID COOLANT LEVEL
    12 111-03 111-03 COOLANT LEVEL SENSOR VOLTAGE HIGH
    12 111-04 111-04 COOLANT LEVEL SENSOR VOLTAGE LOW
    13 174-03 174-03 FUEL TEMP VOLTAGE HIGH
    13 174-03 174-04 FUEL TEMP VOLTAGE LOW
    13 224-11 THEFT DETERRENT ACTIVE
    13 224-14 THEFT DETERRENT ACTIVE WITH ENGINE CRANKING
    14 121-05 1072-05 RETARDER SOLENOID LOW/HIGH VOLTAGE LOW
    14 121-06 1072-06 RETARDER SOLENOID LOW/HIGH VOLTAGE HIGH
    14 122-05 1073-05 RETARDER SOLENOID MED/HIGH VOLTAGE LOW
    14 122-06 1073-06 RETARDER SOLENOID MED/HIGH VOLTAGE HIGH
    21 232-03 620-03 5 VOLT SUPPLY VOLTAGE HIGH
    21 232-04 620-04 5 VOLT SUPPLY VOLTAGE LOW
    21 41-03 678-03 8 VOLT SUPPLY VOLTAGE HIGH
    21 41-04 678-04 8 VOLT SUPPLY VOLTAGE LOW
    24 100-03 100-03 OIL PRESSURE SENSOR VOLTAGE HIGH
    24 100-04 100-04 OIL PRESSURE SENSOR VOLTAGE LOW
    25 102-03 102-03 BOOST PRESSURE SENSOR VOLTAGE HIGH
    25 102-04 102-04 BOOST PRESSURE SENSOR VOLTAGE LOW
    25 102-07 102-07 BOOST PRESSURE NOT RESPONDING
    26 108-03 108-03 BAROMETRIC PRESSURE VOLTAGE HIGH
    26 108-04 108-04 BAROMETRIC PRESSURE VOLTAGE LOW
    26 108-10 108-10 BAROMETRIC PRESSURE SIGNAL RATE OF CHANGE
    27 110-03 110-03 COOLANT TEMPERATURE SENSOR VOLTAGE HIGH
    27 110-04 110-04 COOLANT TEMPERATURE SENSOR VOLTAGE LOW
    28 91-13 91-13 ACCELERATOR PEDAL POSITION OUT OF CALIBRATION
    29 30-08 644-08 PTO THROTTLE SIGNAL INVALID
    29 30-13 644-13 PTO THROTTLE SIGNAL CALIBRATION
    31 84-01 84-01 LOSS OF WHEEL-BASED VEHICLE SPEED SIGNAL
    32 91-08 91-08 ACCELERATOR PEDAL POSITION INVALID
    34 190-08 190-08 PRIMARY ENGINE SPEED LOSS OF SIGNAL
    34 64-08 723-08 SECONDARY ENGINE SPEED LOSS OF SIGNAL
    35 190-00 190-00 ENGINE OVERSPEED WARNING
    36 84-02 84-02 VEHICLE SPEED SIGNAL INVALID
    36 84-08 84-08 VEHICLE SPEED SIGNAL OUT OF RANGE
    36 84-10 84-10 VEHICLE SPEED SIGNAL RATE OF CHANGE
    38 105-03 105-03 INTAKE MANIFOLD AIR TEMPERATURE SENSOR VOLTAGE HIGH
    38 105-04 105-03 INTAKE MANIFOLD AIR TEMPERATURE SENSOR VOLTAGE LOW
    41 84-00 84-00 VEHICLE OVERSPEED WARNING
    42 22-11 637-11 PRIMARY TO SECONDARY ENGINE SPEED SIGNAL CALIBRATION
    42 22-13 637-13 ENGINE SPEED SIGNAL CALIBRATION NOT PERFORMED
    46 100-01 100-01 LOW OIL PRESSURE WARNING
    46 100-11 100-11 VERY LOW OIL PRESSURE 46
    47 71-01 IDLE SHUTDOWN OCCURRENCE
    47 71-14 PTO SHUTDOWN OCCURRENCE
    51 168-00 168-00 EXCESSIVE ECM BATTERY POWER
    51 168-01 168-01 LOW ECM BATTERY POWER
    51 168-02 168-02 INTERMITTENT BATTERY POWER TO THE ECM
    55 NO DIAGNOSTIC CODE DETECTED
    56 253-11 630-11 CHECK TRANSMISSION CUSTOMER PARAMETERS
    56 253-02 630-02 CHECK CUSTOMER OR SYSTEM PARAMETERS
    58 231-02 639-02 J1939 DATA INCORRECT
    58 231-12 639-12 J1939 DEVICE NOT RESPONDING
    59 252-11 631-11 ENGINE SOFTWARE INCORRECT
    61 110-00 110-01 HIGH COOLANT TEMPERATURE WARNING
    61 110-11 110-11 VERY HIGH COOLANT TEMPERATURE
    62 111-01 111-01 LOW COOLANT LEVEL WARNING
    62 111-11 111-11 VERY LOW COOLANT LEVEL
    62 111-14 111-14 LOW COOLANT LEVEL WARNING (LESS THAN 6 ENGINE HOURS)
    64 105-00 105-00 HIGH INTAKE MANIFOLD AIR TEMPERATURE WARNING
    64 105-11 105-11 VERY HIGH INTAKE MANIFOLD AIR TEMPERATURE WARNING
    65 174-00 174-00 HIGH FUEL TEMPERATURE WARNING
    66 54-05 706-05 AUXILIARY OUTPUT #06 CURRENT LOW
    66 54-06 706-06 AUXILIARY OUTPUT #06 CURRENT HIGH
    67 55-05 707-05 AUXILIARY OUTPUT #07 CURRENT LOW
    67 55-06 707-06 AUXILIARY OUTPUT #07 CURRENT HIGH
    68 191-07 TRANSMISSION NOT RESPONDING
    71 43-02 IGNITION KEY SWITCH FAULT 71
    72 1-05 651-05 CYLINDER #1 INJECTOR CURRENT LOW
    72 1-06 651-06 CYLINDER #1 INJECTOR CURRENT HIGH
    72 2-05 652-05 CYLINDER #2 INJECTOR CURRENT HIGH
    72 2-05 642-06 CYLINDER #2 INJECTOR CURRENT LOW
    73 3-05 653-05 CYLINDER #3 INJECTOR CURRENT LOW
    73 3-06 653-06 CYLINDER #3 INJECTOR CURRENT HIGH
    73 4-05 654-05 CYLINDER #4 INJECTOR CURRENT LOW
    73 4-06 654-06 CYLINDER #4 INJECTOR CURRENT HIGH
    74 5-05 655-05 CYLINDER #5 INJECTOR CURRENT LOW
    74 5-06 655-06 CYLINDER #5 INJECTOR CURRENT HIGH
    74 6-05 656-05 CYLINDER #6 INJECTOR CURRENT LOW
    74 6-06 656-06 CYLINDER #6 INJECTOR CURRENT HIGH
    92 285-05 2950-05 INTAKE VALVE ACTUATOR #1 CURRENT LOW
    92 285-06 2950-06 INTAKE VALVE ACTUATOR #1 CURRENT HIGH
    92 285-07 2950-07 INTAKE VALVE ACTUATOR #1 NOT RESPONDING
    92 286-05 2951-05 INTAKE VALVE ACTUATOR #2 CURRENT LOW
    92 286-06 2951-06 INTAKE VALVE ACTUATOR #2 CURRENT HIGH
    92 286-07 2951-07 INTAKE VALVE ACTUATOR #2 NOT RESPONDING
    93 287-05 2952-05 INTAKE VALVE ACTUATOR #3 CURRENT LOW
    93 287-06 2952-06 INTAKE VALVE ACTUATOR #3 CURRENT HIGH
    93 287-07 2952-07 INTAKE VALVE ACTUATOR #3 CURRENT NOT RESPONDING
    93 288-05 2953-05 INTAKE VALVE ACTUATOR #4 CURRENT LOW
    93 288-06 2953-06 INTAKE VALVE ACTUATOR #4 CURRENT HIGH
    93 288-07 2953-07 INTAKE VALVE ACTUATOR #4 CURRENT NOT RESPONDING
    94 289-05 2954-05 INTAKE VALVE ACTUATOR #5 CURRENT LOW
    94 289-06 2954-06 INTAKE VALVE ACTUATOR #5 CURRENT HIGH
    94 289-07 2954-07 INTAKE VALVE ACTUATOR #5 CURRENT NOT RESPONDING
    94 290-05 2955-05 INTAKE VALVE ACTUATOR #6 CURRENT LOW
    94 290-06 2955-06 INTAKE VALVE ACTUATOR #6 CURRENT HIGH
    94 290-07 2955-07 INTAKE VALVE ACTUATOR #6 CURRENT NOT RESPONDING
    95 385-01 2948-01 LOW INTAKE VALVE ACTUATION SYSTEM OIL PRESSURE
    95 385-03 2948-03 INTAKE VALVE ACTUATION OIL PRESSURE VOLTAGE HIGH
    95 385-04 2948-04 INTAKE VALVE ACTUATION OIL PRESSURE VOLTAGE LOW
    97 283-05 2949-05 INTAKE VALVE ACTUATION SYSTEM OIL PRESSURE SOLENOID CURRENT LOW
    97 283-06 2949-06 INTAKE VALVE ACTUATION SYSTEM OIL PRESSURE SOLENOID CURRENT HIGH
    97 283-07 2949-07 INTAKE VALVE ACTUATION SYSTEM OIL PRESSURE NOT RESPONDING
    98 284-05 2988-05 ENGINE COOLANT DIVERTER SOLENOID CURRENT LOW
    98 284-06 2988-06 ENGINE COOLANT DIVERTER SOLENOID CURRENT HIGH
    W903B Thanks this.
  11. E model Cat man
    E model Cat man Light Load Member
    79
    72
    Jun 10, 2014
    Northern Maine
    The rough running problem your describing is most likley the water recirculation valve at the precooler no functioning...they help the motor warm up also by either not allowing or allowing coolant to circulate threw the precooler core. Their is a diaphram behind the valve that can go bad but usually its the 2 wire harness that goes to it and routed behind the turbo and very close to manifold...it becomes melted and brittle from heat and they can short out on motor or themselves not allowing the valve to work. In my experience it normally doesnt through a code. Youll have to run new wires from where they come out of the main harness near the front of the cylinder head by the fuel inlet line. I usually run them up and over the alternator bracket away from the manifold and connect it to the valve near where the heater hoses are fastened to the frame. Stops them from melting again. Hope this helps.
    Oxbow, blade and SAR Thank this.
