Hi guys!!! Help, mechanics wanna broke me!!! every one said its front main seal,but not(replaced allready). but engine still cower from front by oil. oil come from behind fan mount, i'm take out fan, so, oil come from one of studhave to fix this??????
Cat c15 oil leak from behind fan mount?????
Discussion in 'Trucks [ Eighteen Wheelers ]' started by AlexCarHauler, Aug 4, 2014.
Page 1 of 4
Gasket goes around the stud. Fan hub comes loose and gasket slips. Remove studs and clean with brake cleaner and pack the hole with silicone and replace studs. Or replace the front structure set.
JohnP3, baha and AlexCarHauler Thank this. -
The cover gasket
I had oil leak under the fan, later saw I was leaking are pressure going down the road. I put the fan on manual,the leak would stop.Replaced the fan hub and all is good. I drove and worked on this for several days and got lucky.
I would not pack silicone since I don't know where the silicone is going to end up.
What I will do is remove one stud at a time and clean very good and then put it back with plenty of teflon tape, that's how my friend stopped the same leak on his 5ek, and that's exactly what I'm going to do to my 1LW, I have paid three time to get this fix and all they do is the silicon way, thank god silicone hasn't find it's way to the oil and ending in one of the piston cooling nozzle.TheBaron97, joey8686 and AlexCarHauler Thank this. -
TheBaron97, SAR, joey8686 and 1 other person Thank this.
Double nut it. Put two nuts on the stud and lock them together. Then use a wrench on the inner nut to screw it out.
TheBaron97 Thanks this.
Page 1 of 4
