Caterpillar 3176b need help with fuel pedal
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by DieselFuelOnly66, Nov 5, 2025.
  1. DieselFuelOnly66
    DieselFuelOnly66 Bobtail Member
    11
    I have a 1996 kenworth with a 3176b(9CK20958), just a little project to tinker with, but I'm at a loss for getting a fuel pedal sensor.
    I bought the truck and drove it around and everything has been working fine until recent, the original tps finally gave up, the signal wire broke inside the sensor itself.
    The original was a 3E-7700 part number which apparently caterpillar no longer offers. I tried the replacement sensor 266-1466 and it does not work, even tried 204-7949 and same results. From what I understand the 3176b requires an analog output, and the new replacements offered are PWM outputs. I even triple checked the harness and everything on the truck side is good.
    Does anyone know of a sensor that will work for me? I searched online and also tried to find older junk trucks to pull an old sensor from but no luck.
    As of now my truck is just yard decoration
  3. DieselFuelOnly66
    11
    Unfortunately I dont think its seems anything listed as the replacement for 3e-7700 like the 266-1466 are incorrect output, even though, even on cats parts site when you type in 3E-7700, says its been replaced by 266-1466...Unfortunately doesnt work
  4. Big Road Skateboard
    8,043
    47,241
    May 2, 2021
    What is the problem? No throttle response at all?
  5. DieselFuelOnly66
    11
    Exactly just like its unplugged, had cat ET hooked up to the truck when I tried it and just kept saying invalid throttle position and of course it wasn't reading any moment on ET
  6. k108 cat power
    k108 cat power Bobtail Member
    12
    Nov 17, 2018
    Brisbane
    you can try 3176, 3406b peec engines 8tc, 5yg, 2ek, early 4ck 3406b prefix as they are analogue.Use same tps
    The wiring for analogue tps sensor has positive, negative and and signal wire to ecm.
    The positive and negative wires to power the tps are from same source positive and negative that supply ecm.
    These tps dont get their power supply from the ecm
    The only wire to ecm from the tps is the signal wire
    Powering tps from the same positive and negative that power ecm, will eliminate speed burps
    As well these engines have speed buffer for the vehicle speed sensor, this should also have same power supply as ecm and tps stop speed burps
    Speed buffer is pwm for gearbox speed sensor
    Oxbow Thanks this.
