I currently have a Class A CDL but have the restriction of no air brakes. I'm wanting to get that removed and move over to the big rigs. I currently drive a Ram 5500 with 16ft flat bed pulling a 40ft gooseneck trailer. Overall length is 2ft shorter than a standard big rig setup.
I'm trying to figure out a way to get the restriction removed without having to go to a full CDL training school. Any input would be greatly appreciated.
Thank you
CDL A questions.
Discussion in 'Questions From New Drivers' started by Heath O, Feb 14, 2016.
Just go take the test. I believe it's the employers who might seek the schooling. Also, I never knew you could have a CDL with air brake restriction. Sounds odd.
Mike2633 Thanks this. -
You have to retest at the DMV and use a truck with air brakes. Probably have to do a pretrip on the truck which is the hardest part. Google CDL practice tests for your state and memorize the exact wording such as "hose" or "line" or "air indicator" vs "air guage." Some states such as Illinois will flunk you over trivial meaningless semantics.
Some states my just require the written tests. Check with your state DMV as to what they require. -
ajohnson Thanks this.
You won't have any problem with a new job once you get the restriction removed.Probably slide by with a refresher through a company at most. FFE (Frozen Food Express) in Texas might be a place to start.
I mentioned FFE, but also check with Freymiller and Transport America.Jonny1 Thanks this. -
Chinatown Thanks this.
How do you figure your current set-up is only 2' shorter than a "standard big rig"? You've got a 40' trailer, and the typical flatbed trailer is 48' long. Van trailers are usually 53'. Even with that 16' bed on the truck, you aren't as long as a typical tractor...even if you've got a "mega cab". Typical tractor will have 15' or so between the back of the sleeper and the rear of the frame rail, plus a 4-5' sleeper, and quite a bit more hood out in front. When I had a Pete 379/60" and a 48' flat, it was 75' overall length. I'd be surprised if you're within 15' of that...probably closer to 20' shorter.
But on to your question, you've got to retest in a semi t/t with air brakes. If you don't want an "automatic only" restriction, make sure to test in a manual...which doesn't shift like the synchronized transmissions in cars and light trucks, so if you've never driven a larger trucks with heavy duty transmissions, you'll want to get that part figured out before you test as well.
As far as getting hired goes, that all depends upon the company and how hard-up they are for drivers. A company that doesn't see many drivers leave will be less likely to hire you than one that constantly has trucks sitting and loads going uncovered due to a lack of drivers. Insurance plays a role in that, too, but not as much as some like to think. The megas that all require the school or refresher courses are pretty much self-insured, so while they try to blame "insurance", it's still the company wanting to send you to their company-owned school so they take some of your money up front or get away with paying you less starting out than what you should be making.kamen rider Thanks this.
