century 10 speed scratches when going from high to low
Discussion in 'Trucks [ Eighteen Wheelers ]' started by homesick, Mar 8, 2015.
  1. homesick
    homesick Light Load Member
    152
    4
    Nov 26, 2007
    memphis,tn
    Anyone had this problem and what is it
  3. Pedigreed Bulldog
    7,744
    14,393
    May 7, 2011
    Slow down to a speed you'd be driving in the low range (10-15 mph) BEFORE you try to downshift into the low range.
  4. Edgar2191
    Edgar2191 Light Load Member
    178
    32
    Apr 9, 2013
    Does it happend when not in motion just hitting the splitter down. If it does it is the synchronizer
  5. Happily Retired
    Happily Retired Road Train Member
    9,254
    18,118
    Apr 16, 2014
    high plains colorado
  6. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,645
    Apr 12, 2013
    Copperhead Road
    [QUOTE="semi" retired;4496180]It "scratches"???:smt017[/QUOTE]
    That's the new politically correct term for... "it grinds like a mudda!" ;)
    "semi" retired Thanks this.
  7. homesick
    152
    4
    Nov 26, 2007
    memphis,tn
    Are Synchronizers expensive to get repaired and I'll try it sitting still
  8. Happily Retired
    9,254
    18,118
    Apr 16, 2014
    Hi homesick, I didn't mean to make fun of your "regional" dialect. I just never heard grinding called scratching before. I believe the syncronizer is in the back half of the trans., so it may not even have to be removed. Do you move the hi-low lever while still in gear (preselecting) or in neutral. I've had transmissions grind like that when preselecting, and it seemed better when in neutral.
  9. blanco
    blanco Road Train Member
    1,221
    295
    Nov 20, 2009
    Gwinnett County, GA
    Rockwell sync is ~500 parts and maybe 700-1000 labor. Tranny does not need to come down. Maybe a day and its done.
  10. Ranger309
    Ranger309 Light Load Member
    120
    101
    Jun 22, 2009
    If you cant down-shift with two or three fingers you are not synchronizing correctly, or there might be something wrong in the tranny.
    The 5th to 6th or back, it could be the transmission real easy, so I ain't saying its your fault.
    I once drove a high mileage rig back to its buyer, and no matter what I did, up-shifting or down in 5 to 6, that M-F would not go into gear, without slamming it cause the tranny was already busted up. To say he bought a POS is an understatement.
  • Draft saved Draft deleted
