Changing your own tires
Discussion in 'Ask An Owner Operator' started by Gumper, Feb 23, 2018.
  1. Gumper
    Gumper Road Train Member
    1,579
    3,843
    Jan 7, 2018
    Butte, MT
    How many of you O/Os change your own tires either at home, on the road or both? I want to do my own tire work to save money. Looking for any tips on what to carry with me to change tires after blowouts, or for simply changing worn out tires at home.
    I’ll need to buy a bigger bead breaker and a set of large tire irons. Have been changing my own drag slicks which can be a pain since I don’t want to scratch those wheels. On a truck it wouldn’t matter as much.
    Grubby Thanks this.
  3. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    Lowes: 2 yellow crowbars $18 each(tire spoons)
    Harbor freight: 20 ton bottle jack $40
    Harbor freight: 3/4 impact $90
    Harbor freight: 1/2 airhose 50' $40
    I do this kind of work. You will need a way to seal up the tire. A cheetah tank is about $300 but you can make one with a welder and an air tank for about $50.
    Lug nuts will come loose after replacement, they need to be tightened after 200miles
    Rideandrepair, TallJoe, Grubby and 2 others Thank this.
  4. 6wheeler
    2,696
    4,774
    Aug 30, 2009
    You can place the tire under the landing gear and crank it down on top of the tire to break the bead if you don't have a tire hammer.
  5. Chinatown
    Chinatown Road Train Member
    74,669
    169,723
    Aug 28, 2011
    Henderson, NV & Orient
    Dang, that's ingenious!
  6. 201
    201 Road Train Member
    12,275
    25,061
    Apr 16, 2014
    high plains colorado
    Unless you change tires everyday, just take them in.
  7. 201
    12,275
    25,061
    Apr 16, 2014
    I've used outriggers on a backhoe, or a hydraulic jack, be creative. We used to seal the bead with a shot of ether and a match.:angel11:
  8. intrepidor
    intrepidor Medium Load Member
    379
    847
    Aug 24, 2017
    Western Iowa
    Kapowee
    201 and Gumper Thank this.
  9. Chinatown
    74,669
    169,723
    Aug 28, 2011
    Now that you mention the ether, I've seen that done at truckstops. Hadn't thought of it again until you posted it.
    Grubby and 201 Thank this.
  10. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    Drive steer tire up on to flat to break bead. If you're game certainly do your own tires, any money saved goes in your pocket. Make sure you got good lock and chain on any spare you carrying. You really should have a 1" torque wrench, I found a Mac 1" torque for $175 at pawn shop:D
    Grubby and Gumper Thank this.
  11. Ridgeline
    22,367
    116,014
    Just bring it in, it isn't that expensive and if you are that cheap, maybe you shouldn't be owning a truck.
    one time with a difficult tire or getting whacked in the head with a tire iron, you will think twice about saving money.
    wis bang, Vampire, Muddydog79 and 3 others Thank this.
