China: Electric Vehicle Battery Charging Indoors Catches Fire
Discussion in 'Other News' started by Chinatown, Mar 4, 2024.
  1. Chinatown
    Chinatown Road Train Member
    73,519
    165,587
    Aug 28, 2011
    Henderson, NV & Orient
    An electric bike battery caught fire while charging indoors in Jinan, Shandong on February 16. Home surveillance camera captured the moment the fire started and the ensuing explosion caused by the burning battery. Fire crews responded to the incident and extinguished the fire. No injuries were reported.
    China: Electric Vehicle Battery Charging Indoors Catches Fire And
  3. Chinatown
    73,519
    165,587
    Aug 28, 2011
    Common sense should know to never have a charger inside a garage that's attached to the home.
    Put it in a detached garage or detached carport.
  4. Chinatown
    73,519
    165,587
    Aug 28, 2011
    One upscale home in Tennessee burned to the ground when an electric skateboard caught fire inside the house while it was charging.
  5. Flat Earth Trucker
    4,077
    14,983
    Nov 19, 2018
    Remember double A and triple A battery chargers? Those never caught fire or exploded. Unless misused.
    These batteries nowadays cause so much mayhem. Gotta wonder if they aren't specifically constructed to do so.
    Chinatown Thanks this.
  6. Tb0n3
    Tb0n3 Road Train Member
    4,319
    8,288
    Oct 5, 2012
    Earth
    It's a matter of energy density and discharge capacity/internal resistance. The faster a battery can discharge its contents the more that can go wrong when it is shorted. More energy flow means more heat and the lithium ion polymer cells which are most common in high discharge applications have a volatile catalyst that catches fire within the temperature range of a shorted cell. A lot of applications are switching to lithium iron phosphate which doesn't seem to catch fire in the same way so is much safer. The downside to it is the lower maximum output and capacity per volume. All that means is you get less range for the same size battery pack.
