Cleaning out oil in cooling system after oil cooler went south
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Ozdriver, Feb 4, 2026.
  1. Ozdriver
    Ozdriver Heavy Load Member
    770
    1,394
    Oct 16, 2015
    Australia
    Oil cooler put oil in coolant CAT 3408. Changed out cooler, cleaned out radiator with degreaser. There is still some oil left in block and heads, so what do you guys use to clean out the cooling system? Most have suggested washing up liquid and get the engine hot and flush it a few times. Another guy said no, use water soluble degreaser (not petroleum based). If I use washing up liquid or laundry liquid, how much would I use? Cooling system holds 65 litres / 17 US gal
    blairandgretchen and Oxbow Thank this.
  3. Diesel Dave
    9,611
    32,309
    Jan 20, 2010
    Hesperia, Ca.
    Welcome back, haven’t seen you on here for the longest time. Missed the your road train clips.
    I remember seeing a guy many moons ago using Palmolive dish washing soap, and water. Ran the truck in Hi idle for a long time, flush and repeat. Did it twice. This was on a 12v71 Detroit.
    Ozdriver and Oxbow Thank this.
  4. MRMTRANS
    MRMTRANS Medium Load Member
    407
    440
    Apr 28, 2015
    3408? Nice. Except for the fuel mileage I imagine. Dishwasher tabs soap is what I've also heard to use, even for routine flush between regular coolant change. I think I remember being told to run it for 1-2 hours. I've used flush from a shop-and not Cascade. Their directions were to run it for 5-10 hours. But I imagine just bringing up to temp for 1 hour would remove any oil. Any longer would be for hard water deposits, which wouldn't exist when using distilled water. I'd still use distilled water for the flush, and flush one more time with distilled water only to remove any soap left behind in the first flush.
    Ozdriver Thanks this.
  5. JB7
    JB7 Road Train Member
    1,002
    1,771
    Dec 13, 2022
    Laurel, MD
    See video starting at 7:35. Dawn dishwashing liquid is excellent. This is what they use on birds and other animals after oil spills.
    Cat C15 and 3406 Oil Cooler Removal and Install. When Should You Replace an Oil Cooler?
  6. Oxbow
    Oxbow Road Train Member
    13,645
    141,400
    Nov 24, 2015
    It's sure good to see you on here Ozdriver!
  7. Rideandrepair
    17,540
    56,830
    Aug 8, 2015
    Too many suds with regular dish soap. Hard to rinse out. Dishwasher detergent is better. Cascade is probably the best. It has softener in it. “No more spots” lol. I always flushed a lot afterwards using regular garden hose. Then used distilled a time or two. It’s arguably overkill. Cheap insurance.
    W923, D.Tibbitt, BoxCarKidd and 2 others Thank this.
  8. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    dish washer cascade is good distilled water lol never used that in my life garden hose past 50 years works just fine
    D.Tibbitt and Ozdriver Thank this.
  9. MRMTRANS
    407
    440
    Apr 28, 2015
    I'd plan on bringing the system back up to temperature when flushing a 2nd time, and maybe more depending on much oil is in the drain water. Hot water rinses out oil residue better than cold water. And I'd drain while the water is hot. When I have done it, I would drain at the bottom line between the radiator and water pump into 5 gallon buckets, which has a petcock valve pointed towards the ground.
  10. Ridgeline
    22,723
    123,050
    We use Fleetguard Restore Cooling System HD Cleaner
    $35 a gallon.
