Clutch Pedal very hard to push...why
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bubblehead1965, Mar 10, 2013.
  1. bubblehead1965
    bubblehead1965 Bobtail Member
    9
    Myrtle Beach, SC
    I have a 2005 387 Pete. The clutch pedal is very hard to push and has been since I owned it.
    I have just installed a new easy pedal clutch, changrd out all the hardware that attaches to the
    bell housing and the clutch cable is loose and not sticking.
    Does anyone have any idea what the problem might be...can't figure it out here..everything that is involved
    has been replaced. Need Ideas.
    Thanks in advance.
    Rick
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,634
    Oct 11, 2010
    Borispol, Ukraine
    wrong pressure plate ajustment ore broken compensation springs
  4. JohnP3
    JohnP3 Road Train Member
    1,594
    678
    Feb 21, 2010
    Rock Creek B.C. Canada
    When you grease the clutch you need to hold the pedal down, and give it about 15 pumps of grease to get the lube on the slide sleeve. Be sure the cross shafts are greased, you should be able to move the slack in the linkage easily, If not you have to find out why?
    I have seen stiff pedals caused by the pedal itself, the tube rides on nylon bushings and they will sometimes get very stiff, Disconnect the linkage at the clutch arm and see if the stiffness is in the clutch or the pedal asembly.
    The fix for the stiff pedal is drill a 15/64 hole in the tube, and screw in a 1/4 x20 Zert use a nut driver, and grease the tube, they take a lot to fill it and you will have to do it a few times to clean the Bushings.
    Just a thought!
  5. jbatmick
    jbatmick Road Train Member
    2,167
    2,358
    Dec 1, 2009
    hastings, Fl
    Sounds to me like a bent shaft. Start by disconnecting the linkage one piece at a time, starting at clutch. After each dis-connect, try clutch for ease. You should be able to isolate the problem in this manner.
  6. bubblehead1965
    9
    Myrtle Beach, SC
    No linkage....it is a cable on this model and it is good.
  7. Pablo-UA
    7,604
    1,634
    Oct 11, 2010
    Borispol, Ukraine
    Yep, 387....... cabel....
    Ok, one more time.... there is inspection door on bellhousing. Use it to see what a hell is going on inside. I'm sure bad pressure plate. If you keep driving with this problem you gonna get broken release bearing throwing balls inside bell with expencive damage of engine flyghtwheel ore broken cabel.....
    Do inspection now!
  8. crzyjarmans
    crzyjarmans Road Train Member
    3,275
    2,357
    Jun 9, 2010
    Home
    I would suggest taking Pablo-ua advise!
  9. freightlinerman
    freightlinerman Road Train Member
    1,287
    533
    Mar 4, 2011
    Florida
    Push the clutch in like a man. Start doing some leg presses. But, best advice is given above. I'm just trolling. :p
  10. pop's
    pop's Light Load Member
    54
    16
    Feb 3, 2013
    Yulee FL.
    Change the cable I have had old mack trucks do the same thing.
  11. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,717
    Apr 18, 2010
    Tennessee
    Lol, that crossed my mind too. If none of the above works go see the doc! :biggrin_2559:
  • Draft saved Draft deleted
