Cold weather idling 2018 Cascadia DD15
Discussion in 'Freightliner Forum' started by nwdirect, Jan 8, 2023.
  1. nwdirect
    nwdirect Bobtail Member
    I run Alaska trips through canada and bought an 18 cascadia with dd15 (save that opinion lol) because i needed some better mpg. That being said in 10 to -45 degree temps the truck stays running 24 hrs and when sleeping 8 hours I find the 600rpm idle the motor cools down and oil pressure is very good and the dpf filter doesnt fill up and no dpf regens but if i high idle the filter gets full and regens and obviously uses a lot more fuel. If I am able to stay warm at low idle with my webasto heater and keep good oil pressure 40 or 50 psi (the main reason i idled up was to increase oil pressure in other trucks) without plugging up filter and regen why wouldnt i want to idle at 600 and save the fuel (fuel very expensive up north $8-9 gal usd)?
  3. pavrom
    pavrom Road Train Member
    3,188
    7,316
    Apr 29, 2012
    NE illinois
    Why not install the Apu?! I believe newer engines dont like idling
  4. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    937
    1,800
    Dec 15, 2021
    I idle at 800-900 rpms.I don't shut the truck off anywhere north of Edmonton unless I'm plugged in at a terminal.
    Older engines,years ago,didn't do well at low idle in extreme cold.I try to keep the engine around 180 degrees when idling.
    A winter front may help in extreme cold.
    Albertaflatbed Thanks this.
  5. PureLeafTea
    PureLeafTea Light Load Member
    271
    490
    Mar 21, 2013
    One reason would be the manufacturer says don’t idle much and if you must idle - idle it up.
