Considering an APU
Discussion in 'Questions From New Drivers' started by Nuge31, Oct 15, 2017.
  1. Nuge31
    Nuge31 Light Load Member
    80
    54
    Sep 7, 2017
    Hello, I am just getting going, just purchased a 2004 international 9400I with 616k miles. Money is going to be tight for a while. I was pricing out apu's because I can't shake the feeling that idling my motor all winter long will take life off of my isx. I came up with about $8500 for one. Is it a good idea or am I worrying about idling more than I should.. thanks guys
    blairandgretchen Thanks this.
  3. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    at 616k, I think you don't need to worry anymore about excess wear and tear, that ship has recently set sail. You're going to have enough fix-it issues with the truck itself. Better save that $8,500 for tow service and high-priced service shops away from home.
    BB203 and Broke Down 69 Thank this.
  4. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    You can use a bunk heater instead, much more cost effective. Espar or webasto are both very good with the nod going to espar. Only idle when it is so cold you may have an issue starting the engine.
  5. Chinatown
    Chinatown Road Train Member
    74,670
    169,750
    Aug 28, 2011
    Henderson, NV & Orient
    spindrift and Dave_in_AZ Thank this.
  6. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    An APU is something I can justify in the price of a used truck, not so much as an add-on. I don't like to imagine being without mine.
    Dave_in_AZ Thanks this.
  7. Nuge31
    80
    54
    Sep 7, 2017
    I thought about getting a little 2000 way generator and plugging truck in to that a couple hours before starting.. I was thinking a little space heater would keep me warm? Winter rolling in and I live in northeast, that thing will be idling quite a bit.. I don't know from experience, but I hear isx had problems at temps around 30 and below
  8. Moosetek13
    Moosetek13 Road Train Member
    14,656
    18,402
    Nov 1, 2010
    Burnsville, MN
    Have you calculated the cost in fuel and maintenance for both the APU and the truck, divided by the cost of the APU? $8,500 buys a LOT of fuel.
    My company doesn't have APU's for that simple reason. They only keep trucks for around 500k/4 years.
    It is not as cost effective as pressuring the driver to keep idling to a minimum. The initial cost added to the fuel used and upkeep simply isn't worth it, especially with the newer trucks.
    And many owner ops probably see it that way too, considering how many of them idle all the time because they don't use an APU.
  9. Nuge31
    80
    54
    Sep 7, 2017
    Thank you, I will check them out
    Chinatown Thanks this.
  10. Nuge31
    80
    54
    Sep 7, 2017
    I just want to be careful with my motor, I paid cash for the truck and trailer so I am in a pretty good position with this. I could finance one but then I have a payment. How much where and tear does idling do to a motor,, I agree, 8500 buys a lot of diesel, but I want every mile I can get before a rebuild.
  11. Balakov100
    Balakov100 Road Train Member
    3,937
    2,637
    May 10, 2012
    Temple, TX
    I wouldn't buy one.
    No DPF either on that truck right?
