Cruse control dosen't work
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kennylyon, Oct 28, 2020.
  1. Kennylyon
    Kennylyon Bobtail Member
    Got freightliner 98 fl112 c 10 car
    When testing for codes, cruse in either off or on holding down resume I get 5 of 5 both on and off, does this mean the switch is bad? Every thing else works Jake's lights so on.
    Trucking Jobs in 30 seconds
  3. Loaderlou
    Loaderlou Light Load Member
    290
    109
    Feb 24, 2014
    Hi Ken. I’m not sure if a Freightshaker is the same as a Pete, but there might be a clutch switch on the linkage below the floor that operates the jake and the cruise. When you release the clutch it hits a rod that senses it. It’s electronic. My switch was about $200 beans. Check into that
    Rideandrepair Thanks this.
  4. Rideandrepair
    7,967
    16,092
    Aug 8, 2015
    Could be a speed sensor on the trans. MIne has has 2 of them, One on top operates the cruise. Switch on brake goes bad, usually jakes won’t work either. I ran over a year without cruise, before finding out about the 2nd speed sensor. If you only have one, I don’t know if it controls the cruise or not. Something to look into.
  • Draft saved Draft deleted
