Which tool do you guys ise to drain the oil. Since mine doesn’t have the easy drain oil valve ? Thank you
Cummin engine do it your self oil change
Discussion in 'Volvo Forum' started by Roman78, Jul 3, 2021.
I dont have an ISX but it cant be that diffrent from a MX or a 6.7. Basically just a wrench, a filter wrench, a 20 gallon oil pan, a dental pick to get any stuck O-rings off and some rags. Never needed any other special tools.
Edit: i looked it up, the ISX uses a ratchet but otherwise everything is the same.Roman78 Thanks this. -
You can buy the EZ Drain Oil valve.
After you drain the oil put your valve in and then you'll have it there for every time.RunningAces, Bean Jr., Roman78 and 1 other person Thank this. -
