Cummins ISC Normal Oil Consumption ?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by SilverBulletBand, Jul 7, 2020.
  1. SilverBulletBand
    SilverBulletBand Light Load Member
    190
    130
    Dec 15, 2018
    Murfreesboro, Tennessee
    I drive a 2015 Freightliner M102 with 157,xxx miles. I believe it has a Cummins ISC in it. Maybe ISL ? Not sure...
    Anyways, It's using about a Gallon of oil per month. I out on about 2-3,000 miles/month.
    Is this normal oil consumption rate for the miles ? When does oil consumption become a concern ?
    singlescrewshaker Thanks this.
    Trucking Jobs in 30 seconds
  3. singlescrewshaker
    2,031
    15,214
    Dec 31, 2017
    Palmgetto, FL
    How much oil are you adding at a time.?
    I ask only because I made a silly mistake when I 1st got my tractor. About the half full mark on the stick, I'd add half a gallon to bring her up to full. Doing this she'd drink 2.5-3 gallon between PM's. Little did I know, it was just settling to her happy spot..
    As soon as someone said stop doing that, add a whole gallon at the low mark. That was the end of that. It now settles about 2-2.5 quarts low on the stick in the 1st 1500miles or so, & stays there the next 8500-9500miles till its PM time.
    Just a thought..
  4. Lazer
    Lazer Light Load Member
    192
    253
    Jan 22, 2017
    If it’s only a gal per month, I would not be overly concerned.
    If there are no visible leaks, keep rolling.
    Just for giggles, at your next oil change, try a different brand. You may be suprised.
  5. pushbroom
    pushbroom Road Train Member
    1,539
    6,211
    Sep 1, 2012
    Oil consumption becomes a concern when rebuilding the engine seems easier then topping it up all the time.
  6. baha
    baha Road Train Member
    3,425
    1,950
    Jul 25, 2013
    ga
    1st is it dripping on ground or burning it?
  • Draft saved Draft deleted
