Cummins isx 15 cuts out power at 1500rpm
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Jul 21, 2019.
  1. mitmaks
    mitmaks Road Train Member
    1,933
    1,238
    May 16, 2014
    I have my 13 KW T660 with isx15 450hp and it cuts out power at 1500rpm. Diesnt matter if I'm going uphill/downhill loaded/empty. It doesn't accelerate fast either. It takes a bit if time for rpm to go up to 1500rpm. Its almost like its derated but there's no codes. I notice it happens in low gears, high gears I can get it to go past 1500rpm but engine seems to struggle still.
  2. stillwurkin
    stillwurkin Road Train Member
    1,296
    1,918
    Dec 2, 2017
    Could be many things. Fuel filters been changed lately? Mayby a dose of dirty fuel? Air filter(s)? Thats the easy stuff.
  3. HoneyBadger67
    HoneyBadger67 Heavy Load Member
    996
    1,969
    Dec 15, 2018
    Maybe a hole in charge air tube?
    stillwurkin Thanks this.
  4. Petty Cash
    Petty Cash Light Load Member
    96
    104
    Jan 12, 2013
    Pennsylvania
    Optional ECM settings like load based speed control, gear down protection, etc. The ISX I had was a former fleet truck with all the babysitting settings in the ECM. Once I had all that stuff changed, it became a completely different animal.
    mitmaks Thanks this.
  5. Carlinho
    Carlinho Bobtail Member
    9
    19
    Mar 2, 2018
    Harker Heights, Texas
    Can a Kenworth dealer get rid of all the safety parameters on a former fleet truck or does it have to be done by Cummins?
  6. Petty Cash
    96
    104
    Jan 12, 2013
    Pennsylvania
    A KW dealer should be able to. I had the carrier I leased on to at the time do it.
    Carlinho Thanks this.
  • Draft saved Draft deleted
