Cummins ISX 15 High Oil Temp
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MannyAgui, Jul 22, 2021.
  1. MannyAgui
    MannyAgui Bobtail Member
    4
    Jul 22, 2021
    Hello, I have a 2016 kenworth t680 with Cummins isx 15 with an oil temperature problem. I already change oil temperature sensor, water temperature sensor, water pressure sensor, water thermostat, oil pump, engine bearing set. And I still got the same issue. It only occurs when I am pulling heavy because whenever I am empty no matter how hot it is it don’t show the check engine with the wrench. Any ideas? Mechanic wants to do overhaul.
  3. God prefers Diesels
    4,198
    22,246
    Jun 26, 2020
    South Texas
    Did you change the oil thermostat in the cooler housing? How hot is it actually getting?
  4. Dave_in_AZ
    311,038
    Have you gotten an opinion from an actual Cummins shop?
  5. MannyAgui
    4
    Jul 22, 2021
    I haven’t change that thermostat I can’t tell how hot is getting because I do not have anything in the cluster that shows the oil temperature just the water temperature sometimes it is 180 or sometimes 210 and I still got the same code.
  6. MannyAgui
    4
    Jul 22, 2021
    They won’t touch it for obvious reasons (de….)
    Coffey Thanks this.
  7. Dave_in_AZ
    311,038
    That could be the source of your problem.
    Goodysnap, BoxCarKidd and spsauerland Thank this.
  8. baha
    baha Road Train Member
    4,137
    2,832
    Jul 25, 2013
    ga
    Yea and a bit of foot to the floor on a summer day?
    Judge, BoxCarKidd and Dave_in_AZ Thank this.
  9. Judge
    70,594
    Newport, Ar
    I don’t believe it’d be a overhaul issue.
    Probably sensor.
    I know a couple people in AR that have Cummins insight and will work on that kind of engine
    Dave_in_AZ Thanks this.
  10. MannyAgui
    4
    Jul 22, 2021
    Do you mind giving me their info? So I can see if they can take a look at it ?
  11. w9l
    w9l Medium Load Member
    316
    513
    Oct 12, 2013
    Do you not have a gauge for that in your Nav plus or Smart nav? I have 2014 KW with no boost or oil temp in cluster but it does on the gauges screen. Don't start overhauling it. It could be in the tuning and timing. Could be oil stat. It is about 85bucks. Change it. Cooler might be plugged? The bigger question there is with what? I am having very similar issues and have done everything except to change oil cooler and water pump. If I find a cure I will be sure and report it here.
    spsauerland and Oxbow Thank this.
