Cummins ISX 475 Oil Capacity?
Discussion in 'Kenworth Forum' started by Airman89, Sep 18, 2016.
  1. Airman89
    Airman89 Light Load Member
    148
    15
    Jul 8, 2015
    I've looked everywhere and I can't find a straight forward answer. I'm changing filters also. I have found anything from 12-15 gallons for the capacity.
    Does anyone know the capacity of he 2005 ISX 475 ?
  3. AModelCat
    161,244
    IIRC my dad's 2006 ISX he had took around 2 pails and a jug, so about 11 gallons or so. I think the varience you see in capacities is likely due to different oil pan depths in different applications. Best bet if you don't know for sure is to simply just pre-fill your oil filter, then start with 9 or 10 gallons, check the stick, add a little more until its full. Start and run the engine for a minute, shut it down and top it off again after it sits for 10 minutes. Then record how much it took for future reference.
    Bean Jr., magoo68 and Airman89 Thank this.
  4. Airman89
    148
    15
    Jul 8, 2015
    Awesome!! Thank you. I appreciate the quick response. Kudos
  5. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    44qts or 11 gallons
  6. bowhunter67
    bowhunter67 Light Load Member
    283
    549
    May 28, 2016
    rush city mn
    My 2007 six 475 holds 12 gallons thats with filling the filter also
  7. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,144
    Apr 1, 2011
    Broomfield, CO
    All the ISX15 engines I've services have been 43 - 45 quarts, with the variance typically being that some owners use a shorter oil filter than the OEM one.
    Kbhairo Thanks this.
