Cummins ISX cold start rough idle
Discussion in 'Trucks [ Eighteen Wheelers ]' started by NRG, May 21, 2010.
  1. NRG
    NRG Light Load Member
    May 21, 2010
    166
    Thanks Received:
    46
    Lloydminster AB
    I've an 07 Volvo 780 with Cummins ISX 500 and 500k miles, still on original turbo and egr. Lately it started rough idling on a cold start only. Tach idle keeps on fluctuating for 10-15 min or so, at some points almost feels like stalling then settles in, not 100% stable though. No codes or errors shown! Runed full diagnostics at the dealer and it did not show anything wrong!? Any input is very appreciated!
  2. CondoCruiser
    CondoCruiser The Legend
    Apr 18, 2010
    19,726
    Thanks Received:
    18,734
    Tennessee
    Monitor your coolant level closely. Newer ISX's are known for the EGR Coolers going out. They usually start leaking internally very slow and gradually get worse over like 3 months before final failure. They do not show up on any diagnostics. If it's not that, i would have some kind of gasket failure going on.
    The fluctuation is the computer trying to correct the situation by varying the fuel.
  3. NRG
    May 21, 2010
    166
    Thanks Received:
    46
    Lloydminster AB
    Thanks for your advice!
    I have a feeling the problem is in the fueling system (pump, injector, rail). Btw coolant level and temps looks good so far.
  4. mrdevildog
    mrdevildog Light Load Member
    Feb 23, 2010
    75
    Thanks Received:
    22
    Heber Springs, Arkansas
    sounds like its due for a overhead check, id have someone run the rack.
  5. ranga
    ranga Bobtail Member
    Nov 16, 2009
    16
    Thanks Received:
    australia
    sounds like you have some fuel drain-back, surging issues on start up are generally due to air in the fuel, if your priming pump is working then try cycling it 2-3 times before starting and see if that helps? If priming pump is not working then once you start it after 30seconds or so rev engine up to full noise and back to idle several times to purge out any air in fuel system. If either of these seem to help then check for a leak around priming pump mount, debrie in a check vale and any signs of "wetness" on fuel hoses and fittings including around the priming pump.
  6. NRG
    May 21, 2010
    166
    Thanks Received:
    46
    Lloydminster AB
    Thanks guys! I appreciate the replies. The truck has been parked for about 2-3 months period on almost empty tanks, never been fully fueled since then. Planning on taking it out on the road next week.
  7. 05VNLDC
    05VNLDC Bobtail Member
    May 18, 2016
    17
    Thanks Received:
    4
    Houston, Tx
    Sorry to bring this thread back, but i have the same problem.. Did you ever fix this issue. Same engine cm870, rough start when cold, like sputtering after about 15 min it evens out.. i ran my overhead nust last year so that shouldnt be my problem and all fluids look normal w no signs of other contaminants to say it was from the egr cooler.. any input will be greatly appreciated!
  8. me myself and I
    me myself and I Heavy Load Member
    Oct 5, 2009
    732
    Thanks Received:
    312
    vernon hills,Il
    As i recall it can be caused by fuel pump actuators. Also ive seen youtube video with guy taking out check valve . It looked nasty. You might want to check it too
    05VNLDC and Justrucking2 Thank this.
  9. Justrucking2
    Justrucking2 Road Train Member
    Sep 12, 2017
    3,211
    Thanks Received:
    4,293
    Plymouth MI
    How many miles on the truck?
  10. Sipesh
    Sipesh Medium Load Member
    Apr 3, 2014
    617
    Thanks Received:
    1,101
    Colorado
    Both my ISX trucks, one an 09 and one a 07 (cm871 and cm870, respectively) have always had a rough start gallop on cold mornings. Anything below 30 and they'll chug for a while. It's been just normal for mine. Addition of a block heater or running the apu on such nights fixes it.
    If you're worried about an EGR cooler leak, pull open the exhaust recirculation pipes where they rejoin the intake side and look for the green/white telltale snot inside. It literally looks like boogers.
    Trucker61016 and Justrucking2 Thank this.
