I have 2012 Pete with isx and fan stay on now before it's take little longer even on manual switch I checked when I turned off engine fan free both sides when u start engine it's making noise as well
Now it's stay on!whats wrong ??
Cummins isx fan stay on
Discussion in 'Peterbilt Forum' started by Hshappy2, May 13, 2017.
Is your air pressure low? Typically they will run on high gear if you have low air pressure. Also if your A/C is running while your idling they tend to stay on for a long period of time. Thats just the way ISX has it programmed. Ive seen it on every model that has an ISX motor.
Hshappy2 Thanks this. -
There is a switch on the front end of the engine that is air actuated. If it fails fan stays on
This could be your fan clutch worn out or, as stated, your A/C is turning it on. Sometimes the A/C pressure switches fail or the wiring shorts and causes the fan to run continuously or intermittently.
I replaced mine, thinking that it was wore out because it wobbles just a little bit. Turns out it's suppose to do that. $440 from the Pete shop. There's a air line off the fire wall above the engine that you could pull off and put some air to it. The fan clutch will pop back and forth if its OK. That's all I learned about it so far.
Hope this helps.Hshappy2 Thanks this. -
Fan clutch was bad so I replaced now working all good it's 550 dollars from peterbuilt dealer in Cali
77fib77 Thanks this. -
Mine was in NYC.
I can't figure labor as I had other things done with the clutch.
Related Categories
All Dash lights on?
dphillips posted Apr 18, 2024 at 6:43 PM
Adding Jakes to 12.7 detroit
Pete0377 posted Apr 16, 2024 at 6:02 PM
Where to buy my first truck.
Gorilla80 posted Apr 4, 2024
Cab bottoming out on 2010 Pete 387
Ray T posted Apr 2, 2024
Peterbilt 379 Missing and shaky...
Easton379 posted Mar 22, 2024
1977 Pete 359 Brake light stuck on
MikeB503 posted Mar 13, 2024
Why Do Some 379s Have 6 Digit...
Wrench589 posted Mar 13, 2024
Cab blower motor only works...
kwforage posted Mar 8, 2024
Thoughts on new to me 379
Wstardan posted Mar 7, 2024
Where to find parts for 1978...
Pacemaker334 posted Mar 5, 2024
Loading...
Recent Threads
Team driver for XPO
jones 2 posted Apr 18, 2024 at 10:37 PM
U.S. 74 ,Laurinburg,N.C.
mjd4277 posted Apr 18, 2024 at 10:24 PM
Just For Laughs
Long FLD posted Apr 18, 2024 at 10:03 PM
Deadlift
Deadlift posted Apr 18, 2024 at 9:09 PM
Looking for opportunity
BlessedWayy posted Apr 18, 2024 at 8:42 PM
Interested in getting my cdl...
vinnyfibonacci posted Apr 18, 2024 at 8:32 PM
Cat 3406E ID and front cover reseal
W Bench Farms posted Apr 18, 2024 at 8:30 PM
1994 3406e Cat Coolant
rslivelyjr posted Apr 18, 2024 at 8:15 PM
All Dash lights on?
Differential/Lube general question
MIg25 posted Apr 18, 2024 at 5:58 PM
Loading...
