cummins small cam I have a oil leak on little plugs in the passage side of block what are they ? How to stop leaking ?
Cummins sm cam leaking plastic plugs, pass side of above oil pan
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 1970Kenworth, Dec 14, 2018.
Picture? Piston cooling nozzles? Replace then.
Diesel Dave Thanks this. -
I’ll get a picture tomorrow. It could be piston cooler nozzles are they able to be replace from the out side of the block.
The part looks like a 8 Figure 8 turned sideways with a bolt on one side and just a round part flat on the other all one piece -
Thank you I looks it up the part is the piston cooling nozzle I’ll order 2 up cause only two are leaking and I guess just unbolt and push a new one in.
Thank you. -
Yes change them all. They're quite inexpensive and can cause you engine problems.
Cummins tells you to use vegetable oil on the O-rings. They may be very tight going in. Carefully tap them in. -
If you haven't already done so. Go here & create an account (It's Free) Register your ESN. You will have access to Parts & service manuals ect....
Cummins QuickServe Online -
I would guess there is 6 piston cooler nozzles 3 on each side ? Ok I’ll replace all .
I forgot I signed up for that other website with my ESN but I didn’t see any Manuals for the older small cams -
There are six piston cooling nozzles, one for each cylinder.
I do not know about the small cam Cummins, but on the big cam they are all lined up on the passenger side. -
Here’s a video I put up the other day for the n14 cooling nozzles, it should be pretty similar? The video is not that good but at least a visual
