Cycling fan clutch on 34 or 10 hr break
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Edjahman, Jul 21, 2019.
  1. Edjahman
    Edjahman Light Load Member
    251
    131
    Apr 2, 2013
    I've been told that it's bad to let the fan clutch cycle on and off while idling on a 10 hr or 34 hr break.
    Is it really better to just turn the fan on and leave it on?
    It uses a lot more fuel with the fan on, I noticed and I also fast idle at 1100 RPM.
    Thank you!
  2. baha
    baha Road Train Member
    3,074
    1,530
    Jul 25, 2013
    ga
    Flip the fan on and it will save wear on fan clutch and keep a/c colder?
    Diesel Dave and Edjahman Thank this.
  3. 25(2)+2
    17,316
    25,926
    Sep 18, 2006
    the road less travelled
    I haven't had a switch I could turn it on with in a long time.
    Ours all had the fast idle turned down some, the Evolution idles at 850 max. Not all that noticeable when the fan kicks in.
    Edjahman Thanks this.
  4. Edjahman
    251
    131
    Apr 2, 2013
    Yeah OK thank you. I was just wondering if it really makes that much of a difference as far as wear and tear goes on the fan clutch.
  5. 25(2)+2
    17,316
    25,926
    Sep 18, 2006
    Depends on the fan clutch and the idle speed , but the clutch 8s designed for higher rpm than you are idling at, I tried to minimise it by running the AC harder if it was bothering me. Otherwise, I don't worry about it.
  6. swaan
    swaan Road Train Member
    2,693
    3,650
    Jul 12, 2009
    BC canada
    A lot less wear and tear on the clutch to leave it on. And people around you trying to sleep will appreciate it also.
    Nothing worse then a fan cycling on/off all night long when parked beside a guy trying to sleep
  7. pushbroom
    pushbroom Road Train Member
    1,214
    4,739
    Sep 1, 2012
    2 speed fan hubs drop the cycle time considerably. 1 speed is drag from magnets, usually enough to keep coolant and a/c in check. Second speed locks in like a normal fan hub
    spsauerland and swaan Thank this.
  8. Edjahman
    251
    131
    Apr 2, 2013
    Thank you, everyone!
    25(2)+2 Thanks this.
  • Draft saved Draft deleted
