D13 expansion tub plastic connector leaking
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ashtre, Mar 30, 2020.
  1. ashtre
    ashtre Light Load Member
    101
    85
    May 9, 2016
    Guessin i need a volvo shop to find plastic connector on left? Kinda snug on that rubber tube worried if i cut it and put new one on, won't be enough play to reconnect.
  2. PE_T
    PE_T Road Train Member
    Spray or pour some water on it to see where the leak is coming from. Sometimes if you tighten the clamp or install a new one the leak stops.
  3. ashtre
    101
    85
    May 9, 2016
    I wish it was a clamp, it's a plastic thing (prob with o ring inside i'm guessin) that can swivel, and i can see air bubbles escaping from it soon as i cut off engine, seems like the heat has worn it a little, i am approaching 700k mi
    PE_T Thanks this.
  4. PE_T
    Post a closeup picture so we can see the problem better.
  5. Newto Trucking
    Newto Trucking Medium Load Member
    357
    215
    Dec 26, 2013
    NE Illinois
    You will need to replace that hose, they’re notorious for cracking when you try to remove them at a higher mileage, it would have happened sooner or later
    spsauerland Thanks this.
  6. ashtre
    101
    85
    May 9, 2016
    Thank ya
  7. ashtre
    101
    85
    May 9, 2016
    Newto Trucking and PE_T Thank this.
  8. PE_T
    I’m not familiar with that type of connection, but I’ve come across a coolant hose that’s made out of a hard flexible plastic. It came with its own connection.
    Have you tried taking the hose off to see if there is an o-ring inside? You probably want to first relieve the pressure inside the coolant reservoir by slowly removing the cap.
  • Draft saved Draft deleted
