D13 new cylinder head seeping oil
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Lexu, May 16, 2019.
  1. Lexu
    Lexu Light Load Member
    61
    11
    Mar 26, 2016
    Just overhauled the engine and put new cylinder head. After not even 100 miles noticed oil seeping between the head and head gasket on the fron of the engine. Valve cover gasket is dry and also the harness where it goes in the head. Can it be a bad head? Anyone ran in to this problem before?
    Trucking Jobs in 30 seconds
  3. Socal Xpress
    1,606
    1,578
    Dec 6, 2014
    Los Angeles, Ca
    Who did the work? On your other thread did you answer the question about new head bolts?
  4. Lexu
    61
    11
    Mar 26, 2016
    They did use new head bolts. And i did it at a reputable shop in Nc. They are known for builduing engines. They said it.s either the head gasket or the head. They will take apart the head and take it to the machine shop to make sure everything is ok with it. It wouldn.t be the first time that we see a bad new part from volvo.
  5. Socal Xpress
    1,606
    1,578
    Dec 6, 2014
    Los Angeles, Ca
    That's what I was thinking. Its unusual to hear of warped head.
  6. Heavyd
    Heavyd Road Train Member
    7,046
    5,116
    Feb 4, 2009
    "seeping" is hard word to take sometimes. How much are we talking here? It may be just from assembly. I would spray the area with brake cleaner and keep an eye on it.
    spsauerland Thanks this.
  7. Lexu
    61
    11
    Mar 26, 2016
    That's what i thought too. That it was just dirty. So i washed the engine and after it completely dry took it for a road test. After 30 miles checked again and in the same area it was wet again. The oil it's not dripping, just sepping. But that is when it's only bobtail. If i would leave it like that i'm afraid that under a heavy load it will start leaking more.
    Heavyd Thanks this.
  • Draft saved Draft deleted
