daytime running lights
Discussion in 'International Forum' started by localyokal, Sep 12, 2016.
  1. localyokal
    localyokal Light Load Member
    Nov 2, 2013
    140
    Thanks Received:
    64
    can someone please tell me how to disable daytime running lights on a 2007 9400i..it seems like every 6 months or so i am replacing a headlight on this thing..my guess is its because they are burning out from always being on..thank you.
  2. David_Simpson
    David_Simpson Medium Load Member
    Feb 23, 2016
    650
    Thanks Received:
    637
    in a former truck i had, in the fuse panel, i had to remove a relay. it'll be hot if you leave the lights on, to find it.
    but i never removed any such relay's in later trucks, i just leave things alone.
    i am not certain if you remove it, you could get horse whipped, should you be in an accident, and they were not operable.
    localyokal Thanks this.
  3. A21CAV
    A21CAV Road Train Member
    Oct 4, 2011
    1,848
    Thanks Received:
    2,156
    Laredo, TX
    Its probably the connectors at the bulbs. They are weak and a problem even on the newer Prostars. Fortunately they're cheap to replace. I've got a 2011 Prostar built in June, 2010 with the original bulbs but both connectors have been replaced.
  4. localyokal
    Nov 2, 2013
    140
    Thanks Received:
    64
    Maybe the new connectors have an option for daytime running lights or no daytime running lights. That would definitely be the easy way to disable them
  5. A21CAV
    Oct 4, 2011
    1,848
    Thanks Received:
    2,156
    Laredo, TX
    They don't. There have been more than a few times over the years I've had this truck where, in less than good light where I've seen cross traffic start to pull out and hard brake. I wouldn't run any truck without DRLs.
    Bob Dobalina and tucker Thank this.
  6. David_Simpson
    Feb 23, 2016
    650
    Thanks Received:
    637
    another thing to, to consider is the insurance company. if thru an investigation the cops find that the DRL were disconnected,the driver may get hit for being at fault, as he monkeyed around with safety equipment the insurance company can deny any claim against the driver or the company as well.
    really gotta think the whole picture for the price of a what, $12 light bulb?
    thejackal Thanks this.
  7. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,768
    Thanks Received:
    6,207
    Light bulb usually fail prematurely when they are vibrating all the time due to loose pot hold-downs.
    Bean Jr. Thanks this.
  8. gunner76
    gunner76 Medium Load Member
    Mar 11, 2010
    500
    Thanks Received:
    137
    IA
    open your glove box and there should be one breaker and one relay(I think)marked day time running lights. Pull these out and it will disable the DRL.
  9. kwswan
    kwswan Road Train Member
    Jul 26, 2009
    1,938
    Thanks Received:
    10,246
    mcminnville,tn.
    Maybe,maybe not.I have heard some say there was,but on my 99 990i there wasn't a breaker,relay or fuse. I had to go under the dash & unplug them from a box that controlled them.
  10. localyokal
    Nov 2, 2013
    140
    Thanks Received:
    64
    Gonna give this a try thank you
