new compressor no air past 65 psi new air cartridge no leaks in system tanks hold air from shop fill 09 dd14 freightliner
dd 14 wont build air past 60 psi
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by o1reb, Feb 18, 2021.
I'm assuming you have check the air governor.
When was the last time the air tanks were drained? -
After the air dryer, the air goes to the front half of the wet tank. There is a bulkhead inside to separate the back half of the air tank. There is a check valve in there that can fail. After that, the air goes to the primary and secondary tanks.
Also as mentioned, the governor maybe the problem.o1reb Thanks this. -
