Depress brake
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Karm, Aug 10, 2026.
  1. Karm
    Karm Bobtail Member
    2024 Freightliner New Cascadia (DD15 / DT12). New Clutch & CPCA installed. Keeps throwing SPN 521007 FMI 14 (Main Shaft Speed Sensor DzHaw signal implausible) and 'Depress Brake / May Not Shift' after driving 30–120 miles. Replaced Brake Drag Switch, Jumper Harness, Brake Pedal Assembly, 2V Valve, and WABCO Air Valve. Static relearn passes at Freightliner. They replaced clutch and actuator cause bad clutch. Please help
  3. JB7
    JB7 Road Train Member
    1,173
    2,219
    Dec 13, 2022
    Laurel, MD
    Detroit Diesel Service Bulletin 06 02-16: SPN 521007 (TCM) Troubles…
    This is a service bulletin for the exact code you have. Did anyone even check for bulletins etc.?
    Magoo1968 Thanks this.
