Detroit S60 12.7 Oil pressure
Discussion in 'Freightliner Forum' started by SemiDriver76, Sep 20, 2025.
  1. SemiDriver76
    SemiDriver76 Bobtail Member
    19
    9
    Aug 23, 2013
    Running 1500 rpm Speed 61mph oil pressure fluctuating between 40 to 52.
    Idle 39 to 40. When started 60 psi and steady. No issues no codes. Just wondering if this fluctuation normal? Sensor replaced.
    Thank You!
  3. Banker
    Banker Road Train Member
    4,432
    13,936
    Aug 19, 2012
    Mine will start the morning off at around 50 and end up 42-45 when it warms up running the hills hard. It still has plenty of power and nearly 800,000 miles on it since the last inframe. This is fine for this motor.
  4. blairandgretchen
    13,837
    75,764
    Dec 9, 2011
    South west Missouri
    Mine is 70 on start up and 45 running - 700k on inframe.
    Rideandrepair, SemiDriver76 and Banker Thank this.
  5. sbaumann14
    sbaumann14 Road Train Member
    1,235
    1,430
    Sep 1, 2010
    Rhinelander, WI
    Mine is 50-54 start. 30 weight runs 43-46. 40 weight runs 45-48
    Rideandrepair and SemiDriver76 Thank this.
