What’s the left tank run from or to cause that’s the only part that’s orange. Would figure both would be orange by now.
Diesel fuel orange only on left side and truck misses after 10ibs of boost (c15)
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by anthonyar4, May 16, 2020.
Page 2 of 9
You fuel return to the left tank might be slightly lower then the one to the right tank and with water being heavier then fuel it will follow the lower path. When you fueled up last did you fill both tanks?
So that should rule out any water coming from the fuel station cause it would be in both tanks.
Any fuel heaters inline or in the tanks?
Loves not lives
anthonyar4 Thanks this.
Normally fuel heaters are part of the filter bases. I've seen some that are electric and others that circulate coolant through them. If they're in the tank it'd just be a probe threaded into the tank with 2 heater hoses plumbed in.
Page 2 of 9
