Diesel fuel orange only on left side and truck misses after 10ibs of boost (c15)
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by anthonyar4, May 16, 2020.
  1. anthonyar4
    anthonyar4 Medium Load Member
    431
    92
    Jun 8, 2019
    Left tank was filled first. I don’t think it is coolant.
  3. AModelCat
    145,338
    Wonder if maybe you picked up some crap on the bottom of the storage tank?
    Might be worth draining or siphoning out that crap and see if it comes back?
  4. anthonyar4
    431
    92
    Jun 8, 2019
    I’ve been trying to. Nobody can around here and not going to dump 250 gal on the ground lol
  5. lester
    2,819
    7,479
    Jan 2, 2012
    NW, Iowa
    Change your fuel filter before getting carried away worried about other things
    Muddydog79 Thanks this.
  6. anthonyar4
    431
    92
    Jun 8, 2019
    Been trying to do that too.
  7. SmallPackage
    4,524
    13,618
    Dec 20, 2019
    Marion Texas
    This is were having a shutoff valve on each tank like all the older trucks with the crossover had was a plus. You could shutdown the clean tank and isolate it before the contamination mixes into both. If you keep running the engine it will eventually mix and the other tank will be needing to be siphoned too.
    I’m thinking like @AModelCat that crud was pumped into the left tank from the storage tank or the guts of that fuel pump on the island are starting to fail.
  8. anthonyar4
    431
    92
    Jun 8, 2019
    Idk but they pretty much told me to F off lol
  9. SmallPackage
    4,524
    13,618
    Dec 20, 2019
    Marion Texas
    If they truely have a problem with that pump I bet you go back within a day or two and find a orange barrel in front of that stall and a red bag over the pump handle. Lol!
  10. anthonyar4
    431
    92
    Jun 8, 2019
    Oh I’m going to keep calling till I find out.
  11. magoo68
    magoo68 Road Train Member
    3,393
    5,383
    Jun 11, 2011
    st malo mb canada
    Did someone get mad and dump pee jugs in tank?? I don’t think it would transfer because it would have to go through filter..
