We own a diesel Freightliner motorhome that has a 20 year old diesel tank 90 gallons.
I would like to get some advice on how to clean these tanks or do they need to be cleaned professionally.
The diesel fuel is stopping up our fuel injectors and we're having to change the filter out every 200 miles.
Any advice would be highly appreciative!!
Diesel tank cleaning? Best method?
Discussion in 'Questions From New Drivers' started by MelKim, Oct 17, 2018.
Algae in the tanks?
If it looks anything like oil, yes. It's causing our filter to clog up about every 200 miles.
Try KillEm to kill everything in your fuel tank.
If the fuel is bad, replace it. If the filters are bad, they are doing their job, replace that too. If the lines or pump is bad or the tank itself bad, replace that too.
Whatever you do, you must have clean injectors. Failure to do so introduces other really big problems.
I personally never really had trouble with 20, 30, 40, 50 or more year old fuel systems. They just work. Have a shop trace the root cause of the problem and solve it. -
Either that or replace tank and lines.
Keep the tank full when possible, less air means less condensation/water. -
anaerobic algae grows at the water/fuel interface in the bottom of the tank so you need to keep the condensation from building up. get a shop to drain and flush the tank and blow out the fuel lines and start over. Keep the tank as full as possible and add algaecide before long periods of inactivity.
Could also be the fuel lines are coming apart on the inside. Just went through that. Treated tanks and filters were not getting any cleaner. Got bad enough to plug cross over valve. Replaced valves and lines and no more problems.
shogun, Snailexpress and TripleSix Thank this. -
Feedman Thanks this.
If you're plugging a lot of filters it means there's a lot of gunk in your tank.
The best way to solve the problem is get the truck into the shop, drain the old fuel, and steam out the inside of the tank.
Like some of the guys said, put in new lines and valves. It's an expense but if you do it right your fuel problems will be over.
The cost of cleaning the tank and putting on new lines isn't as expensive as the downtime you'll incur fighting bad fuel.
