does a boost leak/problem hurt startability?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dustinbrock, Jun 14, 2015.
  1. dustinbrock
    dustinbrock Road Train Member
    Apr 19, 2012
    1,308
    Thanks Received:
    901
    North Battleford, SK
    been chasing low boost for a while now, have it narrowed down to a leak at higher psi or a bad low side turbo. 2008 c15 sdp acert. now I've got some stupid specs for what I haul..... tuned up cat, 18 speed, 336 gears and I haul 140,000.
    whenever I start I have to use bull low and she still struggles which I expected with those gears and my weight but was hoping the power would counteract that. the fact I'm missing 20+ psi of boost means I'm missing loads and loads of horsepower too but is any of that missing power gonna be down low or just when the turbos are howling?
    just kinda curiousif I'll be struggling to get er going all the time or not. the minor inconvenience of the starting issue is far outweighed by the fuel mileage savings of these specs even with low boost and it'll only get better so the specs will stay the same.
    thanks in advance.
  2. Pedigreed Bulldog
    May 7, 2011
    7,737
    Thanks Received:
    14,421
    Hauling 140K all of the time, I'd be concerned about the durability of the driveline components...especially putting big power through them.
    As to your original question, though, it shouldn't affect startability because generally speaking, you're letting out the clutch at idle when there is no boost being made anyway. The leak will make the biggest difference once the turbo(s) spool up to start producing boost, and pressure escapes through the leak.
    Fix the leak and fuel mileage should increase. Power will increase. Startability should remain the same, though.
    Oxbow and dustinbrock Thank this.
  3. dustinbrock
    Apr 19, 2012
    1,308
    Thanks Received:
    901
    That's kind of what I was thinking. I've got a heavy driveline to handle durability a bit better.
    Oxbow Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    Apr 9, 2009
    3,797
    Thanks Received:
    6,294
    Humboldt, Sk
    As long as you're on a hard packed surface you'll be able to take off. If you're on softer ground you'll struggle. I have 3.91 rears on 11R24.5's. Mine starts off great in most places. One time I overloaded by a few tonnes in a freshly cultivated field, it took off okay but it really moaned and groaned a bunch, and forget about leaving bull low until I got out of the field.
    And I second the motion as startability is dependant upon clutch engagement torque which is usually determined at idle or no more than 800 rpm, so boost is of no effect. But if it's not quite running right low end torque may be effected.
    My last truck had a 450 Mercedes with 3.58 and 11R22.5 tires. I new it would have problems with those rears so I put in 4.11 rears at a cost of $5,000 when I started doing super bees. I never had a problem launching that.
  5. dustinbrock
    Apr 19, 2012
    1,308
    Thanks Received:
    901
    yeah I have 430 in my other super b truck. ran 411 in another, I'm going for the run fast drive slow with big power here and it works so far. same trucks on this run with high power and 390 and 411 gears and I'm saving 100 a day in fuel.
    Oxbow Thanks this.
  6. Cetane+
    Cetane+ Road Train Member
    Sep 29, 2013
    1,304
    Thanks Received:
    882
    Albany, NY
    The replies that have been posted work if you are only talking about the first 2 seconds after you let out the clutch. After that the boost has huge affect. The ECM does not let more fuel in until it sees boost from the sensor.
    Oxbow Thanks this.
  7. RustyBolt
    RustyBolt Road Train Member
    Feb 21, 2015
    2,073
    Thanks Received:
    3,333
    Bement, IL
    If your CAT's boost system has a waste gate (betting it does), it will only make about 31 or so lbs of boost. That's where CAT has them manually set from the factory.
    Also, if you're running it like most by trying to stay near peak torque, you'll never see horsepower anywhere near what your engine specs at. Mine reaches a peak HP of 430 at 2100rpm. Yet I never run above 1500 rpm because peak torque is at 1200rpm. So, (1500/2100)*430=307 HP. And my ScanGuage backs the math. Using those numbers but changing it to 600hp, you'd be getting in the ballpark of 428hp at 1500rpm.
  8. dustinbrock
    Apr 19, 2012
    1,308
    Thanks Received:
    901
    a stock 550 acert twin turbo setup will produce 50lbs boost easy. the singles produce in the 30s. with the tune I have that thing should be well over 60.
    I run 1200 to 1600 rpm. sometimes on a hard pull I'll go up to 1700
  9. RustyBolt
    Feb 21, 2015
    2,073
    Thanks Received:
    3,333
    Bement, IL
    I'm not arguing the point. Just curious where you are getting your numbers from. Mechanical gauge, ECM, or elsewhere?
  10. dustinbrock
    Apr 19, 2012
    1,308
    Thanks Received:
    901
    from the stock guage and my mechanic took it for a drive with his computer hooked up. but I guess that's still not having a manual guage verifying.
