Is the driveshaft supposed to spin when not running
You can turn it when motor is not running
It a vovlo d13 semi
Driveshaft
Discussion in 'Experienced Truckers' Advice' started by Fredferd64, Nov 13, 2019.
The actual drive shaft, no. Should only turn if the truck is moving.
magoo68, truckdriver31 and AModelCat Thank this. -
Sounds like a diff is toast.
HoneyBadger67, FoolsErrand, FlaSwampRat and 1 other person Thank this. -
It may rotate some due slop in gears & u joints, but never more than a wiggle.
truckdriver31 Thanks this. -
If you are spinning it by hand, be careful, it is real easy to run over your self before you realize the truck is moving. lol
Rideandrepair, Infosaur, HoneyBadger67 and 5 others Thank this. -
Just curious, but what difference would it make, unless he was spinning a pto driveshaft?
Tx Countryboy Thanks this. -
What A model said.
