I'm looking at putting a driveway into a small parcel of land I have so I can park my truck and trailers. I'm thinking 30' wide culvert ought to be plenty wide enough but curious what some of you think? I pull a 53' trailer with slider tandems. I staked it and looked at it. I might have to swing out a little if I'm turning from the right into it.
Turning from the left should be A-OK which is probably the direction I'll be coming in from most times. What width do some of you guys have? This is off of a 2 lane county road standard width around this area. Two trucks have no problems passing each other going opposite directions but there's not much shoulder at all.
driveway culvert width? Highway tractor + 53' trailer
Discussion in 'Ask An Owner Operator' started by rollin coal, Apr 24, 2017.
Page 1 of 8
Depends on how wide the road is. On my rural road, 30ft is not enough. Have to put front wheels into the ditch on the other side to get it backed in and pulled out. This was on a 40ft end dump. Truck was 230" WB. On a true 2 lane road, may be just enough. Bigger is better if you can...
Lepton1, rollin coal and blairandgretchen Thank this. -
38.5' is the minimum road width for a 48' truck to make a U-turn. It would be less for a 90 degree turn (especially if you could swing into the oncoming lane), but I'd want some cushion on each side too.
stwik, rabbiporkchop, x1Heavy and 6 others Thank this. -
My culvert isn't near 30' and I get my loaded car hauler stinger in no problem. But I angled my pad so it isn't a 90 degree. The road I live on is angled also to help. Every situation is different. I could put a 53 in easier I think. Not pulled a 53 with a road tractor in a few years. Guy down the road doesn't have 30' wide and he has standard issue Pete 387 with 53 he puts in it. Not sure how he does it as he seems to be home before me.
Lepton1 and rollin coal Thank this. -
I'll be pulling in at 90* to the road. I look at it and 30' looks doable but 40' seems a lot better. Around here the county picks up the culvert and installs it for no charge but I have to pay for the culvert and get it locally. Now I'm wondering if I should just get galvanized steel or go with the reinforced concrete. That will most likely be a price thing surely galvanized is much cheaper. It's probably not going to be more than 15" in diameter so galvanized should be fine.
crb Thanks this. -
DDlighttruck, rollin coal and SAR Thank this.
rollin coal Thanks this.
40' would be my choice. Galvanized will be just fine. I have a 24"plastic the county installed years ago and I have well used it and never had any sinking spots. It's all about the guy running the hoe and how they fill around.
rollin coal and SAR Thank this. -
Page 1 of 8
