Dump Box Trouble
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by RichardsTrucking, Sep 18, 2014.
  1. RichardsTrucking
    RichardsTrucking Bobtail Member
    Once my PTO is engaged my dump box won't go up as it normally did... It goes up very very slowly, I have to accelerate the truck so it can keep going, but it still goes up slowly... When it comes down it comes down as it normally would, pretty fast. I checked the oil... Any one have any thoughts of what it could be? Please help me out. :biggrin_25524:
  3. bad-luck
    bad-luck Road Train Member
    3,292
    6,056
    Nov 16, 2013
    Baltimore, Maryland
    Check the filter. Sounds like there is a restriction somewhere. Also make sure that the pto is engaged all the way
  4. sirstealth
    sirstealth Bobtail Member
    27
    10
    Nov 22, 2013
    Mass
    Had something similar happen because the cable on the dump lever became partly disconnected so even when the lever was fully up it was only going up at a snails pace unless you hammered the accelerator.
  5. 201
    201 Road Train Member
    12,277
    25,062
    Apr 16, 2014
    high plains colorado
    If it's not the up/down control, it might be the pump is worn. Got to be a pressure test on the out line you can try.
  6. poppapump1332
    poppapump1332 Road Train Member
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    Sounds like the pump is weak probably need to replace it
  7. j_martell
    j_martell Light Load Member
    284
    184
    Jun 12, 2014
    Centre Wellington, Ontario
    If a gear driven pto, it's either in or out....if it were slipping, you would know....partial engagement will still spin the pump, and eventually #### the gearing.....
  8. Chewey
    Chewey Light Load Member
    140
    72
    Feb 10, 2012
    Can you hear the bypass valve?
  9. hotrockhauler
    hotrockhauler Bobtail Member
    Sounds like your pto is worn out. new? old? Ever leave it on and drive down the road? high rpms will burn it right up. if new and never got too hot could be clogged oil supply line/fitting ect... usually if in need of bleeding they bounce coming down good luck!
  10. Rodeo_Joe
    Rodeo_Joe Light Load Member
    183
    17
    Oct 24, 2008
    Blackstock, Ontario
    I'd say its your up/down control not allowing much pressure for your up, is it a cable control rod or air?
  11. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    Another thing, getting to be that time of year how cold is it where you're at? Get enough water in the system and it will freeze at the low spot, which is usually in or before your PTO pump on the transmission, therefore cavitating your pump and tearing it up.
