Dvd player to tv
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by PHILIP783, Dec 14, 2013.
  1. PHILIP783
    PHILIP783 Bobtail Member
    What do you need to hook a regular dvd player up to a tv in your cab? Present for a relative and i have no idea? Please help.
  3. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    an HDMI is best assuming the tv and DVD player have hdmi ports. You probably want to buy a bluray player, not DVD. DVD's are kinda old school.
    If no HDMI ports, s-video for the video and component for the audio would be ok.
  4. Olympian
    Olympian Medium Load Member
    334
    169
    Jun 21, 2013
    At least a 300 watt inverter and a HDMI cable, the longer the better.
  5. UTurn1
    UTurn1 Heavy Load Member
    743
    360
    Jan 22, 2012
    Depends on the player and TV. I use my PlayStation and it is regular component cables hooked to that. But an inverter is needed also. If no inverter is installed a 450w DC plug in one works fine. I used to use that until I got a built in inverter.
    snowwy Thanks this.
  6. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    IF he has a laptop with HDMI out and assuming he has a TV with HDMI in (If less then a few years old it probably does) then he only needs the laptop and an HDMI cable running from Laptop to TV then he can play the DVD thru the laptop, to the TV (as a monitor). Otherwise, a newer DVD player and a newer TV, you'll only need an HDMI cable between the two.
  7. Blue02celi
    Blue02celi Road Train Member
    1,230
    289
    Aug 3, 2007
    Melbourne, FL
    like mentioned above, first ya need to know what inputs the TV has unless you're gonna buy every connection possible... coaxial, a/v, hdmi...
  8. snowwy
    snowwy Road Train Member
    20,539
    13,275
    Jul 6, 2009
    hooking up a dvd to a tv in a truck, is no different then being in a house. except for the add of an invertor.
  9. Dr_Fandango44
    Dr_Fandango44 Road Train Member
    1,053
    746
    Aug 27, 2012
    Austin, TX
    If they are very new units then HDMI is the only way to go over the now defunct RCA cables, component and optical cable for audio. In fact many of the newer TVs and DVD machines don't bother with the inputs like S-video as that is dead and gone.
    I agree with one of the previous writes. You are better off buying Blu-ray these days over a reg DVD. Bluray will play both anyway,
    I only use HDMI on all my systems at home and on the truck. But if you have an older TV you may have to compromise and use RCA.
    Good luck.
  10. PHILIP783
    Thank you all for the great info you all have given me!! Drive safe
