Eaton Fuller 13 speed Shifter loose
Discussion in 'Volvo Forum' started by RoadRanger^^, Oct 26, 2025.
  1. RoadRanger^^
    RoadRanger^^ Medium Load Member
    317
    118
    Apr 17, 2018
    Columbus, OH
    Hello fellas,
    Shifter on my truck is very loose in all the gears but especially when is neutral. I went to Volvo dealer and they said to replace the bushing and i did replaced nothing changed still the same. I’m thinking that something in the shifter tower is worn. Anybody have experience with something like this.
    Thank you
  3. SmallPackage
    5,827
    18,679
    Dec 20, 2019
    Marion Texas
    What do you mean loose? Like you can’t tell what hole it is in because the stick has so much slop? It wont stay in gear? A little side to side movement of the stick while in gear even an inch or two ain’t uncommon with a high mileage trans. As long as it still shifts like you want it to and stays in gear it’s still working like it should to most folks. Try shifting a 16 or 20 speed spicer even when new. They were truly loose. You never could tell what gear it went into or came out of most of the time. Like rolling dice. Lol.
    Oxbow, PSM379 and RoadRanger^^ Thank this.
  4. RoadRanger^^
    317
    118
    Apr 17, 2018
    Columbus, OH
    Yes it is very sloppy and i want to fix that if possible. Tranny has 1.2m on it lol.
    I have couple of buddies and they all have Volvo’s and their stick shift is pretty steady nothing like mine. Both have around 1m miles on the trucks.
    i can imagine shifting 16 or 20 with stick shift like that must be really fun lol
  5. 201
    201 Road Train Member
    12,844
    26,443
    Apr 16, 2014
    high plains colorado
    Shift lever isolator bushing, and it's a PITA to change.
    RoadRanger^^ Thanks this.
  6. RoadRanger^^
    317
    118
    Apr 17, 2018
    Columbus, OH
    That is correct. I did replace it and it was really hard to get the metal piece from the bushing, likely i had air chisel and was able to take it out after 2 hours lol
    I have to mention there is difference when the truck is in gear and between gears now it feels tight but the loose feeling in neutral is still there and i think the shifter tower something is siezed in there
    201 Thanks this.
  7. Big Road Skateboard
    7,250
    41,328
    May 2, 2021
    The o ring on top of the stub shaft is probably gone. It'll let the tip of the stub shaft sit higher in the top plate, which makes it feel looser in all gears.
    Eventually it'll pop out while in gear, and the stick will just flop around.
    RoadRanger^^ and Rideandrepair Thank this.
  8. Diesel Dave
    9,775
    33,742
    Jan 20, 2010
    Hesperia, Ca.
    IMG_7999.jpeg Doesn’t the top plate have a or shifter rod have a piece of steel sticking downward that operates the top plate ? That piece wears over several years. I can’t explain it properly.
  9. RoadRanger^^
    317
    118
    Apr 17, 2018
    Columbus, OH
    I just bough the shifter tower. I will change it most likely in the next couple of weeks, once i have some extra free time and will comeback to give an update. Thank you all for the responses
  10. Lazer
    Lazer Road Train Member
    1,850
    2,984
    Jan 22, 2017
    Is there an update?
