Electric door locks, new right one, still doesn't work with remote or left switch.
Discussion in 'Volvo Forum' started by ErieMcDreary, Jul 16, 2019.
  1. ErieMcDreary
    ErieMcDreary Light Load Member
    273
    196
    Dec 4, 2016
    Erie PA
    2016 VNL. Rt door locks with key or inside handle, but will not lock or unlock with remote or left handle (I know, push it twice) . I installed a new actuator, it has a soft click when trying to lock or unlock, same as the old one. Left one has a hard clunk when it works. Everything works easily, and is lubed, wiring does not appear damaged in door. Is there a solenoid or switch somewhere else?
  2. ErieMcDreary
    273
    196
    Dec 4, 2016
    Erie PA
    OK, a lot of views but no answers. I opened up the drivers side door and everything looks good. I hooked up the lock actuator I took out of the passenger side and it made no difference. My brother works with electronics and he suggested looking for a relay. I searched the 'net and found something about a "central door lock module". It is located under the fuse panel. Now to try to find the part# and cost of one of them.
  3. ErieMcDreary
    273
    196
    Dec 4, 2016
    Erie PA
    Success! The door lock module fixed my problem, mostly. The remote now doesn't work for either door, but I can live with that. The doors lock and unlock with the key and the switches on the door.
    I got it used for $60 from ebay seller Arizona truck parts.
    QUALITYTRUCK Thanks this.
  4. x1Heavy
    x1Heavy Road Train Member
    29,384
    33,120
    Mar 5, 2016
    White County, Arkansas
    Toss door.
    Put a old style manual door on there.
    The minute you are on top of old Raton in a -30 white out trying to fix a strap or something and that battery tanks and click. That's your life at risk.
  5. ErieMcDreary
    273
    196
    Dec 4, 2016
    Erie PA
    Why? The key locks work as they should. It is just a convenience to be able to operate the far side door from the driver's seat.
  • Draft saved Draft deleted
