Driving a 2018 cascadia with the 12 speed auto. When I run through sitting water with the passenger side steer tire and water sprays into the wheel well, the dashboard lights up with pretty much all of the lights, our inverter goes bananas with beeping until powered off, and the truck will not shift (stuck in whatever gear it is in). Even if I power off the truck and restart it will go into 1st gear and will not shift from there. This passes after a few minutes whether the truck has been powered off or not.
Any ideas what is getting hit by the water to cause this? Told our shop about it and they said they didn't find any wiring exposed, they replaced the inverter but it's still doing it. Running through rain is no problem, just heavier sitting water in potholes and such. Might take a water hose to it and see if I can figure it out, but thought someone might have an idea.
Electrical issues when running through water.
Discussion in 'Freightliner Forum' started by mem, Feb 16, 2019.
