Electronic air suspension air dump, when shut down.
Discussion in 'LTL and Local Delivery Trucking Forum' started by shortlid, Oct 3, 2019.
  1. shortlid
    shortlid Bobtail Member
    6
    7
    Sep 26, 2019
    New Hampshire
    Company is leasing out a Binder straight truck for a moving job from KC to New England. It has a electronic switch for air dump on rear axle for lower load height. It stays lower when engine is idling. But once you shut it down it reinflates! Anyway to prevent this?
    FlaSwampRat Thanks this.
  2. MACK E-6
    34,877
    125,329
    How about just not pulling the red knob when you park?
  3. shortlid
    6
    7
    Sep 26, 2019
    New Hampshire
    This straight truck does not have the RED manual air dump for suspension. Only the electronic switch.
  4. Rusty Trombone
    Rusty Trombone Light Load Member
    67
    125
    Apr 14, 2019
    Turn the engine off first, then turn the key so only the battery is on, then dump. I’m memory serves you will have to push the switch again to reinflate it when you turn the engine on. It won’t reinflate itself.
    shortlid Thanks this.
  • Draft saved Draft deleted
