I have a 2004 Western Star 4900 with a 14L Detroit and 10spd Eaton Ultra Shift. 2 peddle.
The problem is stutter shifting. Most prevalent 4 and 5 gear while turning also down shifting 10 to 9.
The other problem is the engine misses when under a load but not continuous.
Seems like a fuel restriction. Fuel filter is new.
I've spent thousands on the transmission. I don't think it's a transmission issue.
I'm at a loss a could use some help.
Engine cutting out.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Maddawg2020, Mar 20, 2019.
does it seems like the truck is coughing when it missed with a 14L detroit it's usually turbo or boost sensor, most of the time the vanes do not respond as quick as they supposed to and you get the cough plus a puff of black smoke.
Try doing and over head
Has turbo been looked at? If you are using the VGT turbo replace it with a BW 141402x or equivalent no waste gated turbo. And program the ecm also.
Yes,
PDI turbo with new exhaust manifold, however getting good boost has been an issue. Started at 19 # after thee times back to shop they have achieved up to 29#. Before the upgrade the engine was producing 33-36# of boost.
I've questioned if the correct turbo was installed and they said it was correct.
