Espar Fumes Advice and Operation Help
Discussion in 'Experienced Truckers' Advice' started by Bry, Dec 3, 2022.
  1. Bry
    Bry Light Load Member
    157
    86
    Apr 16, 2013
    If your Espar is properly maintained and cleaned but still gives off fumes, here's 2 pieces advice:
    1. Always start it at max heat for several minutes, THEN after it is hot, set to a lower temp (my max temp is 85 deg.)
    2. If for any reason it goes off, such as the ignition key was turned on, it will go into cool down mode for several minutes and continue to blow the fan--DO NOT turn it back on until this cool down stage is over
    Hope this helps some of you! Those fumes are awful to breathe.
  3. 86scotty
    86scotty Road Train Member
    3,936
    10,232
    Aug 27, 2017
    Appalachia
    You mean you're smelling fumes in the cab? Diesel exhaust or otherwise? Not that it matters, if you are you have a leak which could end your life. You shouldn't smell anything in the cab with an Espar or any diesel heater running.
    Flat Earth Trucker and Hammer166 Thank this.
  4. Bry
    157
    86
    Apr 16, 2013
    The Esparz sometimes burns fuel incompletely when it is turned on again before cool down completes. I think a lot of drivers know what I'm talking g about.
  5. Bry
    157
    86
    Apr 16, 2013
    I no longer have any fumes problems since waiting for cool down to complete.
  6. 86scotty
    3,936
    10,232
    Aug 27, 2017
    Appalachia
    I've had lots of diesel heaters for years (Planar/Espar/Webasto/Chinese) and they are all pretty much the same. I'm familiar with the startup and shutdown cycles. You still shouldn't be smelling more than a very faint diesel smell for a second at startup and nothing in shutdown. If you are super sensitive to this I'm not sure how you can survive around diesel trucks at all. This isn't a criticism, I'm serious. Diesel trucks smell like diesel, even clean new ones.
  7. 86scotty
    3,936
    10,232
    Aug 27, 2017
    Appalachia
    Also, I'm not sure what you mean here because you don't have any choice but to wait for the cool down to complete. You can't stop it from doing this.
  8. Bry
    157
    86
    Apr 16, 2013
    Ok, I will just post this:
    I am pretty sure anyone will save themselves some grief with espars (which i do love)
    Jacoooooooo Thanks this.
  9. Bry
    157
    86
    Apr 16, 2013
    By following these two simple steps:
    1. When u first turn it on, run it at max temp for 5-10 min before u set it to ur desired temperature
    2. If ur espar is turned off, such as becuz u turned on the ignition key, do not turn it back on until it has completed its cool down cycle--ie, don't turn it back on until the fan stops blowing
  10. teams567
    teams567 Medium Load Member
    392
    454
    Jan 3, 2022
    Some people like me have no problem with diesel fumes, but car exhaust makes me nauseous after the first smell. Very sensitive to it too- can smell car exhaust a mile away.
    As far as the Espar, if the wind is blowing strong against the truck, some fumes will get inside on startup. No big deal, just open the window a minute. Also, make sure it's shut off when fueling.
