I have a 2013 Cascadia with DD15 engine,
Ac wasn’t blowing cold when stationary, the Loves mechanic changed the fan clutch, as soon as we turned the engine the fan clutch did not disengage, mechanic said it might be fan clutch solenoid issue. Ac is now blowing cold so that problem is fixed. The fan clutch solenoid was changed 5 days laters, still fan clutch will not disengage.
Any idea what I should look at? help would be appreciated.
Fan clutch issue need help.
Discussion in 'Experienced Truckers' Advice' started by LoneRanger, Jul 12, 2018.
It may be a ecm program issue. But you should check you solinoid older ones are air powered and electric relay.
LoneRanger Thanks this. -
Did the mechanic actually check the fan clutch out or just assume there was a problem?
LoneRanger and BUMBACLADWAR Thank this. -
Check that the mechanic didn't install the fan solenoid backwards.
I changed my fan solenoid at night one time and didn't remember which side of the fan solenoid was the inlet and the other the outlet.
Well, when the fan stayed on and never turned off I figured out I had it on backwards.Lepton1, blairandgretchen and LoneRanger Thank this. -
Some clutches are air applied, spring released. Others are spring applied and air released. If it went from not working to stuck on after changing the fan clutch I'd guess the fan clutch that was installed was not the correct one. Probably was not the original issue and is now causing additional problems.
Since it’s summer time let it stay engaged. When your company notices the increase fuel consumption they will fix it.
Lepton1 Thanks this. -
I had this issue with the fan on the CAT C15 in my Columbia. Turned out to be the AC high pressure switch. The plug had melted and was shorting out. Replaced,.. problem solved.
HurstLoneRanger and Lepton1 Thank this.
