So I just freshly rebuilt my N14 cummins on my 98 KW w900.
I've started it a few times few testing it, moved it out of my shop. Drove it 3 miles. That's all.
Yesterday I was doing some more stuff on truck like brake lines. I topped off coolant and checked the oil. the pan is litterly filled with diesel. And not by a little. It's filled with it.
I followed everything in the service manual when I did the rebuild. Injectors have new orings on it as well.
What did I do wrong or what did I miss?
Feeling Defeated. Fresh n14 rebuild, oil pan filled with diesel
Discussion in 'Kenworth Forum' started by irishluck09, Feb 16, 2026.
Pull the injectors 1 at at time until you find the one with a bad top oring or oring out of place.
Puppage, irishluck09, Sons Hero and 1 other person Thank this. -
You can use fuel dye and a blacklight to find it, or air pressure if no other choice.
Did you drop one during the overhaul?Feedman, Star Rider and irishluck09 Thank this. -
Keep in mind, if the pump seal goes bad it will push fuel right into the back of the compressor and down into the pan…..
Diesel Dave, Feedman, Big Road Skateboard and 2 others Thank this. -
Figured that would be the first thing to check so ill be doing that hopefully tomorrow
I was thinking about trying dye from a buddy who mentioned that to me.
No, when I pulled all the injectors I bagged them up and put them in a crate and labeled them as well. Before install I cleaned them, put new orings on and made sure the plungers moved freely.Feedman and Big Road Skateboard Thank this. -
Is there an easy way to test that? Would it just go bad like that? The truck has sat for about 8 months before I was able to do the overhaul.
With the injectors just being installed I would lean towards them.
As @Big Road Skateboard mentioned air pressure can be used. I've taken the one fuel line off the head and shot air in with a rubber tipped blow gun and found a leak like yours before.Big Road Skateboard Thanks this. -
Had it happen Cummins buddy put air to fuel line T you see the bubbler .
Did pull Jake's to seeBig Road Skateboard Thanks this. -
Im pulling injectors now to check. So far no twist or broken orings and cups are looking fine
