Figureing Loaded weight, question.
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Rickp334, Aug 12, 2018.
  1. Rickp334
    Rickp334 Bobtail Member
    10
    4
    Aug 9, 2018
    Alabama
    When trying to find out what I can haul in cargo do I look at gcwr? For instance the 99 f350 super cab with a 7.3 and 4:10 gears shows a gcwr of 20k. Is that the weight truck, trailer, and load? If so that's not much.
  2. BryE
    BryE Bobtail Member
    36
    57
    Feb 19, 2018
    Yes. That would be truck, trailer, and load.
    Rickp334 Thanks this.
  3. Rickp334
    10
    4
    Aug 9, 2018
    Alabama
    Thanks Brye. That's not very much. Lol
  4. Oldironfan
    Oldironfan Road Train Member
    5,778
    5,383
    May 22, 2017
    You need a dual rear end.
  5. Oldironfan
    5,778
    5,383
    May 22, 2017
    From a semi truck. Would help.
  6. Rickp334
    10
    4
    Aug 9, 2018
    Alabama
    The truck is a dually. Towing guid has it at 20k gcwr unless I'm reading it wrong. If the truck weights 5500 and the trailer weighs 7800 that leaves 6700. That's not very much. It has air bags and I heard that increases gcwr but I cant find anything that says that officially.
    Oldironfan Thanks this.
  7. Rickp334
    10
    4
    Aug 9, 2018
    Alabama
    Lol I see what your saying. Lol
  8. Oldironfan
    5,778
    5,383
    May 22, 2017
  9. Bdog
    Bdog Heavy Load Member
    894
    608
    Nov 6, 2014
    I don’t think the air bags officially change anything thought they do help reduce sag. Trucks have increased tow capacity tremendously over recent years. For example my 2017 dually has a gcwr of around 40k. The newer trucks have better brakes, stiffer frames, stronger engines, better cooling, etc.
    Lite bug and Rickp334 Thank this.
  10. Oldironfan
    5,778
    5,383
    May 22, 2017
    I don't quite agree with this. But new trucks do have way more hype saying everything is better. If this were true why do old trucks/semis do the same type of work new versions do.
  • Draft saved Draft deleted
